Hey all,
I know this is usually done as a dodgey kind of thing but I give you my word I am doing this for a true and honest reason. Possibly because I got jibbed too.
Well I bought a replacement Skyline today an early 1996 s2 mspec. But first thing I noticed was the cluster was different to my S2. Its ugly, it doesnt have the circle things around the indicator things.
Well Ive still got my old R33 in tact and still have the cluster with a reading of 119xxx. I want to put it in my car but the car I bought has 82000. Now, I could put it in and just swap it out later on, but for the
sake of fairness and just well, I like to be honest with my self here, I want to rewind the clock I took out of my series 2 and put it in my series one.
If someone can PM me how it can be done. It looks like an electronic signal is sent from the box controlling the counter inside the speedo. I dont want to break the thing and I dont want to fork out money for
one on eBay with 70000km on it. I know places will trade it in for theirs and they will just rewind it and sell it off, but like I said, this is a true, honest request.
If it can be done it would be greatly appreciated. If you need proof I will take photos of everything just to show I'm not f**king around here.
Cheers.
https://www.sau.com.au/forums/topic/347358-rewinding-the-speedo/
I've done it on my old laser, just to match up the numbers when I swapped a good cluster in to my broken down hunk of junk.
If you have a tiny flathead screw driver (the sort you would use for computer parts), it's possible to get between and kind of seperate the numbers from each other, then turn the numbers to what you want...... then remove the screwdriver and it should click back in place.
This also has potential to wreck the whole mechanism. I would never do it on the skyline cause the clusters are actually worth decent money lol. But the laser cluster cost me $20, so I thought I'd give it a go.
For anyone reading this, thinking I'm a criminal... let me tell you..... when I changed the ODO on the laser, I was actually winding it FORWARDS to match :)
not sure what exact part of the new speedo you like, but 1 option may be to simply change the speedo part of the cluster to put your current cars speedo and odometer into the cluster you like the look of more. this way you still have the legitimate kms
mad I think you're onto something. I just popped the face off the new cluster. Im gonna remove the old one from the car and see if I can pop the face off that one. The cluster in my car is just flat. The one ive got is like a new design and like all the icons have circles around them. it just looks crisper.
Fingers crossed they line up! Can anyone confirm if the lights and indicators are all in the exact same place?
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
