Hey all,
I know this is usually done as a dodgey kind of thing but I give you my word I am doing this for a true and honest reason. Possibly because I got jibbed too.
Well I bought a replacement Skyline today an early 1996 s2 mspec. But first thing I noticed was the cluster was different to my S2. Its ugly, it doesnt have the circle things around the indicator things.
Well Ive still got my old R33 in tact and still have the cluster with a reading of 119xxx. I want to put it in my car but the car I bought has 82000. Now, I could put it in and just swap it out later on, but for the
sake of fairness and just well, I like to be honest with my self here, I want to rewind the clock I took out of my series 2 and put it in my series one.
If someone can PM me how it can be done. It looks like an electronic signal is sent from the box controlling the counter inside the speedo. I dont want to break the thing and I dont want to fork out money for
one on eBay with 70000km on it. I know places will trade it in for theirs and they will just rewind it and sell it off, but like I said, this is a true, honest request.
If it can be done it would be greatly appreciated. If you need proof I will take photos of everything just to show I'm not f**king around here.
Cheers.
https://www.sau.com.au/forums/topic/347358-rewinding-the-speedo/
I've done it on my old laser, just to match up the numbers when I swapped a good cluster in to my broken down hunk of junk.
If you have a tiny flathead screw driver (the sort you would use for computer parts), it's possible to get between and kind of seperate the numbers from each other, then turn the numbers to what you want...... then remove the screwdriver and it should click back in place.
This also has potential to wreck the whole mechanism. I would never do it on the skyline cause the clusters are actually worth decent money lol. But the laser cluster cost me $20, so I thought I'd give it a go.
For anyone reading this, thinking I'm a criminal... let me tell you..... when I changed the ODO on the laser, I was actually winding it FORWARDS to match :)
not sure what exact part of the new speedo you like, but 1 option may be to simply change the speedo part of the cluster to put your current cars speedo and odometer into the cluster you like the look of more. this way you still have the legitimate kms
mad I think you're onto something. I just popped the face off the new cluster. Im gonna remove the old one from the car and see if I can pop the face off that one. The cluster in my car is just flat. The one ive got is like a new design and like all the icons have circles around them. it just looks crisper.
Fingers crossed they line up! Can anyone confirm if the lights and indicators are all in the exact same place?
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
