haha, those would just look insane on a stagea or a audi rs4/6!! i was soo hyped up i couldnt even spell EPIC, haha.
bet you a singel rear tyre will set you back like 500 bucks for a cheap one.
sometimes i wish i was rich :(
  • 2 months later...
Wheels look hideous.
Sorry, but just because something has a crazy offset and is wide, doesn't instantly make it a awesome looking rim. If the spoke design is hideous (like those) it is still a shit looking rim, no matter what the offset.
Shit:
Not shit:
I'd prefer a wheel with no dish with a great looking spoke design/colour than something that simply has dish but looks shit.
i think they look hot, but not made for skylines, you can only have certain rims on jap imports that suits them, same goes for euros.
volk for japs and bbs for euros. thats always going to be like that. euros have the styling and japs have something more toy like.
but those rims would look crazy on a merc or porsche. that style imo is more for the luxurious, not for the sports car
Oh I quite understand that these are not a "Skyline" design wheel, that is not my point. They look shit regardless if they were on a Stagea or an Aristo. As said above, there are plenty of nice deep dish wheels suited for the whole VIP look, those are not one of them and I don't understand why you all like them other than the fact they have "Hektik dish bro!".
cus they so hektik bro.... no, not really, i just like the look of them and i guess so do others. every person likes different looks in rims, i do prefer the "tuner" rims for a car personally, but if you want to go VIP, on a nice phat s600 then this is one of the best choices, they just look nice and beautiful.
id love to put BBS on a skyline, but i wont becaus from my view they look shit on a skyline.
i found a really nice set of bbs a while ago which actually looked really wicked and maybe a bit extreme, but they were a 1 off make for bmw, they were 15X15 rears and 15x11 front. you could have fit another rim just in the dish if you wanted to ;)
that rim/style of rim suits heaps of cars i run DH eurolines on my car which look identical gotta have knackers to pull it off, but eh each to there own cant all rock the same shit ay
Those rims are pretty bad looking.. but i love them! Not just cos of the size.. there's just something about them. Would rock them on a Cedric or something VIP
that 350z also looks gangster
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
