hey guys just want to find out from ppl who have experience with your after market paper inlet manifold gaskets if there alrite to use?
I fitted up a greddy COPY manifold 2yrs ago, re-used the factory metal gasket and never skimmed/shaved the manifold and finally it let go on the weekend.
I dropped manifold at engine centre now 2 be shaved, what im wondering is do i need to buy a genuine metal gasket? or can i use afer market paper one ? do i use any special sealant on them? some tips or advice would be great thanks! Reason i ask is because genuine is around $90 and your after market ones thru protorque etc are alot cheaper $50 mark
Edited by l0WRB
https://www.sau.com.au/forums/topic/347379-inlet-manifold-gasket/
Genuine 98bux!!! Umm last week started leaking and has been miss firing on cold start ups, finally let go sat night and coolant was leaking into cylinder 2 and 4 so glad it all happened before powerplay in january!
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
