Hi sydney kid...I have a sandblast cabinet so i blasted them with glass beads first then they were polished to a mirror finish...next the surface must be free from all polish and foreign matter(its extremely important...more so than with other paints as this paint is transparent and if you get fish eyes or silicon spots then you have to start again)The paint is 2k and must be painted in a completly dust free enviroment as any dust or crap in the paint will show up and a big black spot( this is due to the candy gathering around a speck of dust..therefore a darker patch in that area)The heavier the material is applied....the darker it becomes as i said in the above post,very shapey parts are very difficult to get the surface looking uniform.The part should then be baked at approx 80 degrees....obviously its not spray can material...its a 2K product by a japanese company called ROCK the colour available are very wide from blue purple gold green red and can be mixed to acheive a custom colour........Its important to use the correct material as normal candy will not stick to the polished surface,i guess some adhesion promoter may make it stick but i am unsure on how this would affect the finish......I am quite sure this is the product that Nissan used on there 34 GTR engines from that factory as when i blasted it off there was no primer or nothing under the original paintwork,I remember i painted some R34 covers for a 34 that was repaired when i was in japan and 99 percenet sure its the same stuff i got from the nissan dealer........the covers could have been painted over the original finish but a inferior finish would be acheived
Hope that helps
I still have some material left if you need a set done
https://www.sau.com.au/forums/topic/34738-anodizing/page/2/#findComment-695556
  • Replies 52
Hi ylwgtr2, no problem with sand blasting we have a cabinet. Polishing I'm not so sure about whether it is worth the time. What happens if you paint it onto a freshly blasted, clean surface, rather than a polished surface?
Thanks for the offer, but I don't think I could pay for the time it must take. I might be able to justify a swap though, anything you need?
https://www.sau.com.au/forums/topic/34738-anodizing/page/2/#findComment-695570
id say you will end up with a finished product like the 34 RB26 engine...the polishing is definately the way to go...but horses for courses i guess......i dont really need anything at the moment but an IOU would be accepted :)
https://www.sau.com.au/forums/topic/34738-anodizing/page/2/#findComment-695576
i have machined a bit of titanium in the past....i cant say i remember it being gunmetal grey :S
I'm an Aircraft Maintainance Engineer by trade, and I have seen many titanium parts. The guy sitting beside me right now (laughing, by the way) used to mandrel bend titanium tube for aircraft, and the colour we chose was the closest to raw titanium that we could find. Freshly machined titanium has a brighter finish though, and I assume that is what you are talking about.
Regardless, the customer was extremely happy with the result, and that's what counts. :D
https://www.sau.com.au/forums/topic/34738-anodizing/page/2/#findComment-696696
That's a beautiful colour for piping... Your customer has better taste than you do, "Bling Bling Mark" :D
Hey dude, I said I prefered it to the polished look. We were a little uncertain of how it would look, but after I fitted it up we couldn't believe how nice and clean it turned out.
https://www.sau.com.au/forums/topic/34738-anodizing/page/2/#findComment-696725
DOH!!! I thought you said you prefered the polished look :D
Okay okay, you have good taste too :D
https://www.sau.com.au/forums/topic/34738-anodizing/page/2/#findComment-696736
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
