If ya have the manifold and gate, then yeah not a bad option for the price.
especially if your aim is to get rid of stock turbos and have a nice responsive replacement.
otherwise if you don't ... then GTX3076 + manifold/gate IMO.
Or go twins. Twins workout cheaper slightly.
He said he already has it...
Too small on the turbine side for a 26 imo, would be responsive but choked in the top end.
If it were me, I would sell it and use the money you wouldve spend on the gate and manifold and buy a pair of -9's
Would make the same power and not be a defect magnet
He said the turbo... nothing about the gate/manifold etc which is what i said in the rest of my post...
if its just the turbo, as stated, then the rest of my post covers that too.
Sorry guys i have the full setup on my neo stagea so i would need to put a different flange on the manifold but have the wastegate and made all the pipework and everything to suit the stagea. If the turbo will be good on a 26 i would adapt whatever i had to so it wouldnt cost me anything really.
If its not a good option id put stock looking twins on the gtr when i could afford it.
