Anyone got one of these? Ive got the same (except in psi) and for the life of me i cant work out how to stop the start up noise (never really bothered me until now. Im sick of the 5 second screaming noise whenever i turn the car on) the instructions say to hold down the peak button when starting the car.. It doesnt work - ive tried all other combinations i.e holding it down when car is completely off then turning it on... having it on accessories then holding it down and starting the car.. nothing seems to work!
Also being that my skyline is fairly stock im hearing a slight scraping noise near the turbo. I was thinking the turbo is on its way out but it still makes approx 10psi by 4000rpm-5000rpm. The turbo was on its way out surely it shouldnt still be making decent boost? (I've tested it by turning down the boost - then upping the boost to get R&R)
Edited by defari
Turbo noise could be the bolts holding turbo onto manifold. Most RB25DETs seem to have this issue. Just pull back the metal locking tabs, and be shocked at the fact the nuts will be finger tight.
Make sure the gauge is wired correctly. If the constant and switched 12v is hooked up wrong you cannot turn off the beep.
Once thats sorted,
Press the button on the gauge and Hold
Switch the ign on
Let the gauge finish the opening ceremony
Then let go
f**k i have got a water temp and a oil pressure of the same brand and it shits me to tears. I feel like smashing them after listing to them over and over. I have done what KWS explined but mine will make the noise once i turn it off and back on again. So maybe mine is wired in wrong!
Edited by Ad's
dude your turbo is f**ked.... 10psi by 4000 and a scraping noise means it's time for a new one :/
on the other hand here is the perfect chance to upgrade....
crisis + opportunity = crisitunity
cheers for the heads up lads
time for a new turbo i think.. might go buy myself a xmas present :D
  • 3 weeks later...
    • That's f**ked up. I'd guess it's more likely that you have an entire S13 subframe in there. Does it still have HICAS mounting points? Seeing as it is quite possible that yours is the only such converted car in the world, you'll probably struggle to find someone who can tell you from direct experience. 'Twere I you, I'd be looking for 4 stud Skyline rear brakes and convert back. At a minimum. Preferably go find all the stuff you need to put it back to 5 stud (assuming you're happy to change wheels) and upgrade to some decent brakes. You don't even need much stock stuff. Don't need calipers or rotors, as you can go fully aftermarket. Just needs hubs and the other bits and bobs that are different to what you have now.
    • The engine has nothing to do with it. The physical space behind the headlight is the limiting factor. And the height. The height of the NS70 is the same as stock. So the clamp bar across the top goes on nice. The battery tray is big enough for it to sit on. The X is for extra capacity - it has even more lead in it than the non-X NS70. Heavy f**ker. But it's not a track car, so I will suffer a couple of extra kg. In the case of the R34, maybe the physical space there is not as deep (forward-backward, not up down). Hence why they say the 60 is the biggest. But I would never trust a catalogue to tell me what will fit. I have the car. I have the existing battery. I have the tape measure. I have the dimensions of all the available batteries. I find the biggest box that will go in. (With the right terminals in the right places, of course).
    • Hello! I have been having a hard time finding the answer to this question… I have a R32 GTS-T Sedan than has been 4 lug swapped using S13 hubs, rotors, and brakes. The front has also been converted to S13 suspension.    When the swap was completed, the handbrake cables were never hooked up, as the S13 rear calipers are the “handbrake”, and not the typical drum on rotor that the R chassis are. Does anyone know handbrake cables that will work for this conversion? I’d like to not use a hydraulic handbrake and stick with the traditional cable style. My original thoughts were to go with S14 cables and try to make them work, since I’m pretty sure S13 cables will be too short.    Any help would be appreciated!
    • I did some research, considering you have a neo engine, how is that battery compatible? I checked centuries website and super cheap and says it's not compatible. Only this full size one is. https://www.centurybatteries.com.au/products/ns60-mf
    • No, lets be honest here. I went to Winton and did a track day, for all the mods and V8 power and craziness I posted up a time that a K24 stock motor Honda Accord can do on the same tyres (narrower, too) 250kw and learning how to drive the f**kin thing is the sweet spot.
