Ive been DECC 3 times already for "noise" pollution and all 3 times have gone to that "granville guy" and passed. Its not difficult, trust me on this one.
lol why would you go through the trouble of fabricating pieces thats going to take you a couple of hours to make and fit when you can just go borrow a standard exhaust and slap the thing on in 30 mins. Much easier, simpler and a GUARANTEED pass. Its a N/A car after all.
hahaha a couple of hours no way.
How many hours will it take you to find someone with a standard exhaust, go pick it up, swap it over, put your exhaust back on and then take it back?
I made a BOV blanking plate for my mate in about 30mins yesterday so its not hard at all
Just got the metal piece behind the cat put in, holes drilled and steel wool stuffed in, cost me $50 but its much quieter.
Just got off the phone to the "approved" list of mechanics. Granville. $60. what a joke that i need to pay for this aswell.
My mechanic sed my exhaust is 3" going to 3 1/4 back to 3". HAHA i always thought it was a 2 1/2 " who in there right mind would put bigger on a NA.
hhmm might do them both. He check the heat temps on the cat, It has not been punched out. I thought he drilled a few to man holes in the metal flange piece, but its better, might whack one behind the muffler like you say.
Booked in For granville next week.
Edited by sydking
yeah mate - if you had told us that you had a silencer in the car we would've told you that they do not accept them. they will accept a silencer that is welded in 3 spots (tak welded only). it doesnt have to be completely welded. this is why we recommended the guy in campbelltown - he actually knows the rules.
hmm got it welded on the way home, i called and asked what type of weld he wanted, he sed any along as it becomes "part" of the exhaust, got a rough mig weg the whole way round.
My noise DB reading came in at 89.7
Why exactly cant you have an FMIC? I can understand the atmo bov but cmon. This is starting to become beyond a joke. There are plenty of standard cars out there which are louder than skylines. The amount of shut the f**k up commodores I hear these days, all drive around untouched.
What is the point of all this? To create hassle and headache for us. Are the Nismo exhausts legal? Its got two really big mufflers on it and its really dead quiet, even under WOT its not really that loud. I'm gonna hang onto it just incase...What about a sealed enclosure around the intake? What about a return flow FMIC which doesnt hinder the structure of the car?
Edited by SargeRX8
to be honest i didn't even know it was a silencer, just assumed a dodgy cannon. the inspector tried to pull it out ect and noticed it was tig welded on the inside. Hence i didnet see the point at all why the outside needed to be fully welded. See how i go on Wednesday morning aye.
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
