Ok, here's the story,
I started my drive from canberra to the Gold Coast at around 11 30 on sunday arvo. The car (my R33) was going really well, loving the highway and the room to stretch her long legs. I was sitting pretty until we hit the light horse interchange and I noticed that the temp guage had moved to about 3/4 I thought it could have been because of the long drive and I was running everything, So I turned off the aircon and kept going. We got off the highway to head through sydney and the first set of lights we hit the temp gauge jumped right up the the line before the 'H" so I pulled over and there was water pissing out of the overflow bottle. I let her sit and called NRMA, he came out and notice a few small leaking pipes but nothing major. And jeremy told me about a manual overide switch for the thermo fan. SO at about 5pm I started off again. Once again just plowing along. I was fine until 0300 when I was just north of Coffs Harbour and I heard a strange noise when I hit one of the thousand pott holes in that road. I heard it again about 30 seconds later, still not sure what was going on. So I looked down at the dash and noticed the battery light was off, once again I was running everything so I just turned off the radio. As I went around the next corner I noticed the power steering had died. Anyway I was about 2 mins from a servo so I pulled in there and had a look in the engine bay and there is my Harmonic balancer sitting off at a really bad angle.
I got towed into woolgoolga and they confirmed (the next day) that the crank had been totally flogged out. So in the next week she's getting a new crank, new harmonic balancer, new bearings, new oil pump, new thermostat for the radiator, and new radiator lines.
OK well now that's off my chest lol.
To make this topic interesting how about people post up their own "epic journeys" where everthing has just gone wrong
Cheers,
OB
https://www.sau.com.au/forums/topic/347498-the-epic-journey/
Pissed n Broke now? I can tell you own a Skyline.
As we blokes say "tits n wheels will send you broke".
I liken it to be a bit like marriage, but at least you can fix a car up.....
A lot less expensive too :P
Yeah I have that problem too... A boob job would cost about 10k... Plus car expenses...
Nah it's being rebuilt with decent parts. The cheap part is the larbour. The guy only charges 77$ an hour. Nispro wanted 180$ an hour for labour. But yeah i'm putting all dencent parts in it like ACL race bearings, I geniune RB26 crank (gonna see how much an HKS drop forged crank is) and loads of other stuff I can't remember
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
