Ok, here's the story,
I started my drive from canberra to the Gold Coast at around 11 30 on sunday arvo. The car (my R33) was going really well, loving the highway and the room to stretch her long legs. I was sitting pretty until we hit the light horse interchange and I noticed that the temp guage had moved to about 3/4 I thought it could have been because of the long drive and I was running everything, So I turned off the aircon and kept going. We got off the highway to head through sydney and the first set of lights we hit the temp gauge jumped right up the the line before the 'H" so I pulled over and there was water pissing out of the overflow bottle. I let her sit and called NRMA, he came out and notice a few small leaking pipes but nothing major. And jeremy told me about a manual overide switch for the thermo fan. SO at about 5pm I started off again. Once again just plowing along. I was fine until 0300 when I was just north of Coffs Harbour and I heard a strange noise when I hit one of the thousand pott holes in that road. I heard it again about 30 seconds later, still not sure what was going on. So I looked down at the dash and noticed the battery light was off, once again I was running everything so I just turned off the radio. As I went around the next corner I noticed the power steering had died. Anyway I was about 2 mins from a servo so I pulled in there and had a look in the engine bay and there is my Harmonic balancer sitting off at a really bad angle.
I got towed into woolgoolga and they confirmed (the next day) that the crank had been totally flogged out. So in the next week she's getting a new crank, new harmonic balancer, new bearings, new oil pump, new thermostat for the radiator, and new radiator lines.
OK well now that's off my chest lol.
To make this topic interesting how about people post up their own "epic journeys" where everthing has just gone wrong
Cheers,
OB
https://www.sau.com.au/forums/topic/347498-the-epic-journey/
Pissed n Broke now? I can tell you own a Skyline.
As we blokes say "tits n wheels will send you broke".
I liken it to be a bit like marriage, but at least you can fix a car up.....
A lot less expensive too :P
Yeah I have that problem too... A boob job would cost about 10k... Plus car expenses...
Nah it's being rebuilt with decent parts. The cheap part is the larbour. The guy only charges 77$ an hour. Nispro wanted 180$ an hour for labour. But yeah i'm putting all dencent parts in it like ACL race bearings, I geniune RB26 crank (gonna see how much an HKS drop forged crank is) and loads of other stuff I can't remember
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
    • That's exactly what I told myself. I'm happy it came out.
    • My bet is there's a fuse somewhere you blew that feeds power to the ECU. Or you've bumped something out behind the dash board.
