Wtb: Rb26Dett Oil & Water Lines
Adrian P
 Share
I need quite a few pieces of oil & water lines that run around the engine, If anyone has the hard / soft pipes that run around the block, over the front cover, under the plenum and back behind the block to the turbo side (including the t-pieces that bolt into the block on the turbo side).
The only thing I don't need as the lines actually on the turbo, and from the turbos to the adapters in the block (but I need the T / Y adapters & banjo bolts on the block for the turbo oil / water.)
Let me know what you have.
  • 3 weeks later...
 Share
