if you do a run with the exhaust dropped and you make more power then you will know the restriction is there... it's a quick and easy way to diagnose a common problem
i'm guessing your cat is collapsed and hindering flow.
you have the parts to make the power you want, just need to get them sorted
if money is really burning a hole in your pocket, go the plazmaman plenum as the stock ones that have been canverted to front facing can lean out no 6. it's not definate, and there are definately 2 schools of thought on the matter that have been hotly debated over the years, but the fact remains that in some instances it has happened, and on that basis i would not run a cut'n'shut plenum on my RB. having said that i do run one on my 4age but that's a 180 deg change, not 90 :)
dont bother with e85 just yet, get the car sorted @ ~340rwkw on pulp and then when you want e85 it'll be a quick and cheap retune... although for this you WILL need much bigger injetors.... think 1000cc
Something is choking it really bad!
Is there a rag in the cooler pipes, blocked/collapsed cat/muffler?
the 426hp run is a lot better.
What do Mercury say about it?
When it was making 426 hp , the car had a couple of illegal mods on it . Like screamer pipe , Atmosphere Bov & Ram pod wasn't boxed in. I got all these mods fixed & made legal . Would this effect performance at all ? Mercury did have a little problem re tuning the car , but nothing which was major & they didn't mentioned anything to me. The only real main problem was the Ecu had to be sent back to Microtech to be cleared , cause the previous tuner put a password on it & we couldn't get it off them. So when it got cleared , they had to start a new tune from scratch . Other then that , all went apparently well & i was really happy with there work on the car. When driving the car home didn't feel any worse , then before i gave it to them , but still really haven't had the chance to really open her up ! They said final results were around the 280 - 290 rwkw.
The only problems with taking the exhaust off & seeing if it runs better , is i live 2 hours south of where Mercury are situated. There is no good local tuners where i live , which are worth taking the car to. So would have to make a 2 hour trip back north to do that ! When i had the car on the hoist the other day did notice the cat & muffler were a bit worst for wear , a bit of scrapings & light dins . The cat especially , also hope there is no rags in the cooler piping , cause they did do a bit of pipe work from the bottom of the turbo which go's to the FMIC. What would u suggest i do about this problem i have ? Take it to a local mechanic for a quick look or exhaust place .
Sounds like you live in ballina or something. Don't worry about the workshop just ask if you can have a couple of runs at the local dyno with the exhaust dropped and see if it makes a difference.
Yeah live at Lismore , do u know this area up this way ? Yeah could try a local dyno around here, i know there is one in Lismore & Ballina . So would just take the exhaust off where the cat bolts upto , then put it on the dyno for a run ?
I lived in tweed heads for 12 years lol. Just unbolt the exhaust at the front pipe (so the cat is unbolted too) and give it a run. Won't hurt anything and will give an indication if what is going on
Thanks for the help , i'll see if i can fit it in before X mas. If not will have to be in the New year . Skyline is only a weekender , so only take it out when i feel the urge to :laugh: Hopefully this will shed a little more light on the situation !
Edited by Tweaky
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
