What are everyone's thoughts on club locks? are they a waste of time? or are they worth it? I think that most skyline owners have alarms/immobilisers.... is it worth getting a club lock as well?
If so anyone have any recommendations as to which brand/model?
https://www.sau.com.au/forums/topic/34758-club-locks/
anyone have any idea of how much this costs - i'm looking at the website but can't find any figures
also for anyone else reading this thread i found a page that had comparisons between club locks..
http://todaytonight.com.au/stories/214589.html
https://www.sau.com.au/forums/topic/34758-club-locks/#findComment-695268
i use a club lock as well as having an alarm.
if it means that a potential thief has to get through that aswell as the alarm, then it will take longer. which gives them more chance of being caught.
also get an immobiliser, and if your really worried then pull out a well chosen fuse. then for the car to be stolen they have to break in, stop the alarm, get through the club lock, bypass the immobiliser then know to look in the fuse box and replace the fuse (if they have one). then if the car gets stolen, it was just meant to be.
https://www.sau.com.au/forums/topic/34758-club-locks/#findComment-695522
any ideas what fuse to pull? my skyline doesnt have the original owners manual so i dont know what fuse iz what? and yeah anyone able to give info on wheel locks how they work and cost etc? i always turn my wheels to lock position aswell so if the break into the car and put it in neutral and remove the brake, they then still have to bypass the steering column to turn the wheels from lock.
and just quietly aybee i love ur avitar!
https://www.sau.com.au/forums/topic/34758-club-locks/#findComment-695604
CEREALKILLER how much was ur quicktrak, does it do anythuing else apart from satelite tracking?? and are you happy with it, i have a full alarm with sensors3pt immob and all the other features, nut am considering getting quicktrak aswell cause i have no insurance.
https://www.sau.com.au/forums/topic/34758-club-locks/#findComment-696446
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
    • I was chatting with an ex SAU person who is involved in chooning euros now. He was saying the factory cars like Audi VW etc have something like 2000 tables that the ECU uses for getting everything "just right". Compare that back to any aftermarket ECU, and you'd be hard pressed to surpass 50 lookup tables. Even the Ford Barra engine has a few hundred lookup tables to run it (and they're still working some tables out too!)
    • Grab a temp probe, and probe each exhaust inlet runner with it sitting idling. Each one should be pretty darn close to the same temp. If you've got some reading higher or lower than the others, it's likely either air flow isn't equal, or your injectors aren't equal to each other.   The other things to check, is from the wiring changes that were made, were any earth's or grounds moved/changed.   Lastly, for the strut brace issue. It's not perfect, but can you get away with slipping a washer or two under the strut brace to raise it, and it still clean the bonnet? If you can, work out the height you need, that the motor can't torque up into, and get a spacer made for each side.
