  • Replies 42
Nice times. Did you do any runs without NOS?
Not last night mate. I'm waiting for the time when i run out half track and spew fuel out the back :) Best run without gas was 13.471 @ 104.56 (2.2 60').
2rismo, what kind of nos setup are you running
It's a butchered kit that i threw together. Mostly NOS. Wet.
coz it defeates the purpose of this thread title about the fastest time with stock turbo i recon.
If you read the first post it will all become clear.... Jeez, some people.... You just miss the point completely...!!!!!
Anyway good effort, u must be running atleast a 100hp shot of nos
Wrong.
Adrian
IMHO I think the reason you're getting a bit of flack is due to the thread title itself, it contains no reference to nitrous assistance. Whack a 'nitrous assisted' in the thread title to make it clear perhaps?
Some people may read the thread title and skim through the posts and think your full of shite as your comparing stock turbo + nitrous vs. stock turbo no nitrous. It's a bit of an "apples vs. oranges" situation.
The question was:
What is the quickest ET / MPH that an R32/R33/R34 GTS-T/GTT has run with the std turbo intact and untouched?
It doesn't need to, the question was 'stock turbo'. Adrian is using a stock turbo so where is the problem?
I'm personally not a huge fan of Nitrous simply because I want my car to be able to do the same on the street as it does on the track but hell a full 1 second gain just from adding 50hp of NOS is something i'd highly enjoy doing even if it is just for that 12.5sec every Wed nite.
Everybody:
If you read the first paragraph of the first post it will ALL BECOME CLEAR!!!
It is in English, isn't it? Look. I have been researching the whole nitrous oxide use thing for years now. Along the way, I have come across NUMEROUS suggestions that it is 'better' or 'more worthwhile' or 'not cheating, you cheating bastard' to upgrade the turbo on my/any car. What I'm trying to show is that this is that nitrous oxide use IS a valid, effective AND relatively cheap method of making more power and going quicker.
I am not big-noting myself by comparing my 12.5 run or any other runs for that matter with anyone elses. I mean, some people have gone high 12's with no gas!!!
The point is this, I have spent significantly less than what I would have in upgrading the turbo to get similar results. End of story. I hope it is a bit clearer now.
Adrian
Dear oh dear, you guys are taking this faaar too seriously :) Chill out fellas.
I couldn't agree more, nitrous is a great low cost way to make solid hp gains. It's not exactly anything that wasn't already well known. Some people think it's cheating, once again nothing new there either!
I personally think nitrous is a great little addition. However, the cost/hassle of going for a bigger turbo (plus the other upgrades this requires) is worth it for the permanent hp gains achieved. Gains that can be used 24/7.
Edit: From memory Adrian posted $100 for a 10lb bottle refill. Which lasts 200secs at 50hp. That's a lot of 12sec passes!
On a totally different issue, does anyone know what the fine is for using NOS on the street?
I've got a theory thats its cheaper than the fine for running without a Cat....10rwhp vs 100rwhp....
    • I had no transmission at all so I managed to find a big box manual gearbox from an R34 GTT for an insanely good price in EU. I converted it to push type which cost more than the transmission almost, with parts from Amayama! These engines are very strong and can put out decent power with a properly sized turbo. You can save on money from parts like pistons and rods, and invest those in the transmission and other parts. I suggest you join the RB20 Enthusiasts facebook group, plenty of info and almost daily posts there about 20DE/DET/Neo+T builds. (I hope I'm not breaking any forum rules by mentioning third party platforms, just trying to help the buddy out)
    • Yeah, having tried all of those methods including BBQ+recipro/hacksaw, I ended up buying a bush press kit under $150 that works well, like this: https://www.ebay.com.au/itm/355967727167?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=sfmmuhxgqhm&sssrc=2047675&ssuid=dJvnaZ11TB-&widget_ver=artemis&media=COPY It basically has a range of pushers and cups with threaded rods between to press out a range of large bushes. The problem with any sawing solution is minimising damage to the subframe side, although it probably needs a quick sand afterwards no matter what solution you try due to damage
    • Hi. Thanks for the answer. I do not have instagram 😄 I too considering turbo the RB20DE NEO 🙂 But i think i upgrade the gearbox first or at least buy new.
    • Just pulled the passenger apart so got a good idea, also the side bracket that pivots the top half is completely cooked.. how I don’t know.. haha and paid $400 also included a photo of the passenger seat! She is mint
    • I managed to get the foam will the original upholstery off in one piece, so will be an easy to re fit thankfully.
