  • Replies 42
Nice times. Did you do any runs without NOS?
Not last night mate. I'm waiting for the time when i run out half track and spew fuel out the back :) Best run without gas was 13.471 @ 104.56 (2.2 60').
2rismo, what kind of nos setup are you running
It's a butchered kit that i threw together. Mostly NOS. Wet.
coz it defeates the purpose of this thread title about the fastest time with stock turbo i recon.
If you read the first post it will all become clear.... Jeez, some people.... You just miss the point completely...!!!!!
Anyway good effort, u must be running atleast a 100hp shot of nos
Wrong.
Adrian
IMHO I think the reason you're getting a bit of flack is due to the thread title itself, it contains no reference to nitrous assistance. Whack a 'nitrous assisted' in the thread title to make it clear perhaps?
Some people may read the thread title and skim through the posts and think your full of shite as your comparing stock turbo + nitrous vs. stock turbo no nitrous. It's a bit of an "apples vs. oranges" situation.
The question was:
What is the quickest ET / MPH that an R32/R33/R34 GTS-T/GTT has run with the std turbo intact and untouched?
It doesn't need to, the question was 'stock turbo'. Adrian is using a stock turbo so where is the problem?
I'm personally not a huge fan of Nitrous simply because I want my car to be able to do the same on the street as it does on the track but hell a full 1 second gain just from adding 50hp of NOS is something i'd highly enjoy doing even if it is just for that 12.5sec every Wed nite.
Everybody:
If you read the first paragraph of the first post it will ALL BECOME CLEAR!!!
It is in English, isn't it? Look. I have been researching the whole nitrous oxide use thing for years now. Along the way, I have come across NUMEROUS suggestions that it is 'better' or 'more worthwhile' or 'not cheating, you cheating bastard' to upgrade the turbo on my/any car. What I'm trying to show is that this is that nitrous oxide use IS a valid, effective AND relatively cheap method of making more power and going quicker.
I am not big-noting myself by comparing my 12.5 run or any other runs for that matter with anyone elses. I mean, some people have gone high 12's with no gas!!!
The point is this, I have spent significantly less than what I would have in upgrading the turbo to get similar results. End of story. I hope it is a bit clearer now.
Adrian
Dear oh dear, you guys are taking this faaar too seriously :) Chill out fellas.
I couldn't agree more, nitrous is a great low cost way to make solid hp gains. It's not exactly anything that wasn't already well known. Some people think it's cheating, once again nothing new there either!
I personally think nitrous is a great little addition. However, the cost/hassle of going for a bigger turbo (plus the other upgrades this requires) is worth it for the permanent hp gains achieved. Gains that can be used 24/7.
Edit: From memory Adrian posted $100 for a 10lb bottle refill. Which lasts 200secs at 50hp. That's a lot of 12sec passes!
On a totally different issue, does anyone know what the fine is for using NOS on the street?
I've got a theory thats its cheaper than the fine for running without a Cat....10rwhp vs 100rwhp....
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
