Hey guys,
Basically when I'm not playing beats I will get a low volume, high pitch whine through my speakers and the pitch will change dependent on engine rpm.
Higher rpm = higher pitch
Lower rpm = lower pitch
Not really too bothered bout this one but would be interested to find out why it happens.
https://www.sau.com.au/forums/topic/347624-high-pitch-whining-through-speakers/
You have a ground loop. There should be plenty of information on these forums and the web in general about how to solve it now you know the term. Listed in order, the simple & typical things you'll want to check are:
* Power & RCA/speaker cabling to amplifer running down opposite sides of the car
* Adequate grounding from the amplifier to the chassis
* Adequate grounding from the headunit to the chassis
* Adequate grounding from the battery to the ciassis
There are also ground loop isolators you can add in, but they will compromise the sound quality & if your wiring is right you should never need them (In all my years of installing amplifiers, etc - I've never needed them).
Thanks heaps mate!
Did some searches and wasn't getting any results - probably due to me not knowing the terminology. My battery is not currently clamped down so I might start there and get it clamped down first as this may be compromising the battery to chassis earth.
also Check the engine to chasis earth
:Arthur
Sounds like you headunit uses the ground from the durry lighter
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
