hey guys im looking at different options for my vl with a rb25. i was thinking of getting custom made intercooler piping
however if i was to get a rb25 kit and modify pieces of it what would you guys think i would have to mod or would i be better with a vl turbo kit
I bought a RB25 intercooler kit and fitted it upto my HR31 with a RB25. A few extra silicon hoses and it fits, i turned my cooler upside down so the tanks were at the top and it works fine. I didn't cut any holes or do anything to the body of the car, my pipes went between the headlights. Might be different for a VL though.
we just about Build your CAR JOEL,
do you need NEW post every time.
haha you almost have haha i jsut keep running into problems as i go along but much appreciated of everyones help i have got so much more done in the last 2 months than i did in 2 years of it being off the road
and ads i will try that its mainly the comp housing thats the diff between vl turbo and rb25 and i think the rb25 will work the best just may need extendin in some areas to accomodate for the larger engine bay.
My intercooler piping is off a vl so I'd say it will work
vl turbo kit or rb25 kit?
and ads thanks again considering i have a little bit more room in my engine bay it should be a little bit easier haha
The piping kit should work on different coolers as long as the inlet/outlet on the intercooler is in the same spot on both. My GK Tech cooler has 3" inlet and outlet at the bottom on each side FYI
yeah but the gktech cooler is smaller so the piping is suited to that however i found a piping kit with the same set up on the for a larger cooler
Looking at a stock engine bay on a VL turbo, I would personally tackle the job by means of an off the shelf VL cooler kit along with the addition of some cleverly positioned silicon joiners.
It appears just about everything is in the right spot, just needing to extend or reposition a couple of sections to suit the difference in motor/intake design and the same for the turbo (comp housing as stated and position).
Was a decent question IMO, simple resolve too. Best of luck.
hey guyys got a vl turbo intercooler piping kit yesterday most of it fits up well oulet from cooler to throttle body connects up fine with one cut to make it fit the standard crossover pipe however to compressor housing is a diffrent story. i have 2 ways of doing cutting a hole just above the chassis rail sideways or cutting a hole where the airbox used to be and buy a 90 degree joiner and a straight piece of piping. only prob is cutting hole sideways above chassis rail if i was to do that the power sterring lines get in the way so i may go with the hole where airbox was. ill keep posting how im going.
going to be a few days however due to christmas and damn missus wants to go out
hey guys ran into another problem the vac line from actuator needs somehre to go i have read you can t piece it off BOV however i removed my carbon canister and put a screw in the line on the manifold next to the throttle body (not the one on throttle body) would this be a good place to put it or would it onl be a vac line not boost also?
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
