Chassis
• OEM strut towers must be retained and used.
• OEM floor must be retained.
• OEM firewall must be retained. Modifications to the firewall are allowed for roll cage, engine fitment, transmission fitment and wiring. All holes must be sealed. If the firewall is provisioned for to allow clearance for a different engine or allow gearbox/drive train fitment, all material must be replaced with the same thickness sheet metal as the factory material.
• The rear most part of the engine block may be no more than 2 inches rearward of the most forward point of the firewall, If the vehicle is rear engine, the front most part of the engine block may be no more than 2 inches forward of the most rear point of the firewall.
• Chassis rails may be modified for fitment issues, all chassis rail modifications must be submitted to the promoter for approval.
• Tube frame chassis extensions are NOT permitted
Can’t see how this is close to CAMS Sports Sedan Specs, yes some of the cars running would be able to run in Sports Sedan with some aero taken off. But far from Tube frame and mid mount motors.
So let me get this right. You can now have tube frame cars, but Porsches are still not allowed?
The mind boggles.
The "No rear engine 6 Cylinder or above vehicles allowed" is only for Clubsprint.
Porsches are allowed in Open and Pro Classes.
http://www.worldtimeattack.com/index.php/cyber-evo-returns-to-defend-the-title/
“We will only be doing one event in 2011 and that is World Time Attack, we had such a fantastic experience last year”
Doesn't have to comply with CAMs spec , very few do, comply with CAMs rules and why should they - one doesnt - two don't nor do the rest - and as if they! are about to do anything about it the next decade! I think you will find most organisers are happy with FAI stamp these days
We had a great time at SL, got some tune issues to sort on the link G4 system, we will be in club sprint 2011, hopefully both cars, (R32 & R33) maybe even a VZ taxi in open
Heard a remour CAMs Actually now means Confederation of Australian Motorsports sux - what a shame!
Chassis
Can't see how this is close to CAMS Sports Sedan Specs, yes some of the cars running would be able to run in Sports Sedan with some aero taken off. But far from Tube frame and mid mount motors.
Someone wanna buy me a turbo kit so I can have a crack?
Old man is about to start advertising his 1995 Turbo MX5 to buy some new Honda motor bike. Runs a Mazda Familia GTR motor and turbo, RX7 S6 gear box, Guru LSD, Motec, Willwood brakes, Koni coil over’s. 220kw@wheels, CAMS log booked with full road rego and engineers report all for $20,000. Would be a nice upgrade for you!
Chassis
The rules you have quoted are only for the Open class. In the Pro class there is no mention of disallowing tube frames and there is no mention of having to USE the strut towers (just that you have to keep them - I wonder how much of them you need to keep?). It has no mention of having to use the OEM suspension design at all (it explicitly states this in the Open class).
There is also no mention of needing to keep the OEM floor in the Pro class. From what I can read, it looks like the only things of the original chassis you need to keep are the strut towers and the firewall. You do need to get permission to modify the chassis rails, so presumably they expect you to keep those as well? They really do need to clarify the class rules a bit better, it's open to wild interpretation.
Good to see that it looks like Porsches (and Fezzas, Lambos etc) can at least now enter the Pro and Open classes.
Good point mattah I just scanned threw Pro Class rules thinking they were the same. Glad I’m not entering the pro class.
As for tyres looks like the Advan AO50R will be the most popular pick or any one got any other ideas?
Anyone got any feedback about running the soft or medium compounds in AO50R, how soft are the soft tyres or most people using the mediums?
Good point mattah I just scanned threw Pro Class rules thinking they were the same. Glad Im not entering the pro class.
For a GTR I reckon mediums are soft enough. Unless if it's super light weight.
From memory last year the yanks were using Hankooks and panspeed were on Dunlop 03G's so it's not all Advan.
I'll be running AO50's again.
So you going to have kiddy fliddling 25 power for 2011 SL Russ or are you going to be sticking with 20 power?
Russ has gone to a dirty cheater 25 I hear..........
It's true.
Check out the build photos on facebook. Engine being dropped in next week all going well. Prob going twin scroll T4 housing on my 3076, mounted on Noel's (FineLine) 6boost that will be in the post when postal services resume in QLD. Should be about 280-300 reliable killa wasps. I'll be starting up a build thread when I get a chance. Maybe not as epic as yours bris.
I want a 1min 42 in august :P
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
