Same thing I thought incidentally with 600rwkw dyno pony...
Put a GT35 on it, then there would be interesting... If you can keep it pointed in the general direction of forward of course :D
It will have weight advantage on it's side though to be fair. It's a SL or similar so IIRC they are around 1250-1280 stock which isn't bad. Final weight would be interesting with the heavy Ford 9" but reduced fuel tank etc.
Didnt notice the 9" part.
LOL 9" diff in a VL that is a "circuit car" and not a drag car
Did some google, looks to have some sort of 4 link in the back but thats about it...Cant find any real details about from "it makes 11ty horsepowers"
Variety is the spice of life!
Good to see more than just a bunch of evo, wrx and gtr's going around.
That said, I don't think it will set any records. If it adds aero and some good sized rubber, it could be reasonably quick.
At a recent supersprint at EC, the old Larry Perkins VL Group A racecar reeled off a 1:48, so I would expect this VL to be similiar and perhaps a bit quicker. 1:45's?
I say 10 :)
At least the ba had v8 supercar suspension.
And tyres they are twice as wide lol.
I did notice in the pics the VL is on full slicks...might be even more intersing once he throws some semis on it.
Standard VL guards are tiny....he would be lucky if he could get 235's under it at that ride height
Googled him:
Street Commodores says, "Jason is currently fitting up his 12in wide ROH wheels and mid-way through a wide-body conversion to help the car in the aerodynamics and traction department"
And on calaisturbo the owner said it's "1380kg with driver before the nine inch, so bloody heavy with that in". He also said he hasn't driven it with this engine/power or on semis.
I couldn't find any times for the car except drag and dyno results.
What do people think about this entry? Absolutely flying at Mallala recently and with more power and room to wind up it should be quick!
http://www.worldtimeattack.com/index.php/open-class-team-toyomorpowa-dyno/
Also has too much horsepower to be useable.
Look at the Pro Class cars, with the Exeption ofMark Berry and Lofty most of the quick cars had around 550hp give or take.
No need for 800hp circuit cars...espesially RWD ones.
Sold the car
Really?
Was only talking to him and is was sitting in the shed not that long ago. They decided to give WTAC a miss this year.
Lofty is a busy boy playing with his stupid fast Toyota Starlet in IPRA atm which does 42's around the creek with a restrictor :thanks:
Really?
Oh...I thought he sold it...was for sale then the ad was gone from my105.
my bad
42s for an IPRA car is fkn flying!
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
