Yeh, ring Race Brakes in WP, tell them about your drama and see if they can get you sorted. The std lines are absolute rubbish in my books as they go to the back of the caliper and not to the std hard lines so when you add lock they ouut tension on the lines :(
And just a question, why isnt there a rule tha states aero cant be a certain percentage over the original dimension or track/wheelbase of a vehicle? I am looking at picks up of an S13 and its way out there!!!! The front wing adds about 50-75% of width to the car...and extends waaaay forward as well. All a bit crazy in my books
I don't have any pics mate, but I've seen some of the cars Roy's referring to.
I'm sure some pics will surface soon enough.
Good news, Mark, Russ and team arrived at EC this morning after driving through the night with both cars in tow and another dual axle trailer full of body kit and fuel :)
The 34 fits on the trailer with about an inch to spare either side now :)
You'll have to swing by and look under the bonnet won't ya! :P lolol
And testing? Yeah, heaps of em. I see some Japanese guys in pit lane with RX7's now, and the Brissy R35's are there too. There's a gaggle of evos standing around looking boring as batshit as well :P
Edited by Marlin
Oh and Timmy, Russ was asking if you were coming up? Hitch a ride with Benson if he's still coming ya champ!
Would love to, but full steam ahead with the EVO to prep it for Rally Aus ATM, damn bodyworks set us back a month!
wow ... Seems like next year the only 'logical' step in regards to aero development is to have wings that are mounted in an unsprung manner, chassis with sliding skirts and rear mounted radiators with large 'cooling' fans ....
Then we'll having dual chassis and active suspension designs all on semi slick tyres :P
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
