Should do alright with the long straight at EC then.
RH9? as in the 9'sec Drag R34 thats never run a 9?
No thats CRD's RH9. Willalls RH9 is an AUS delivered R32. Still in the top 5 quickest GT-Rs in OZ i think. They've converted it into a time attack car now.
http://www.nagtroc.org/forums/index.php?showtopic=42616
the R34 RH9 is now looked after by godzilla motorsports and i believe it has run a 9. I'm at work atm so can't do link but i'm pretty sure there are video's on you tube of the run(s)
Nah, I'm hoping to do Classic Adelaide too, and there's just not enough time between the two events to transport and reconfigure the car to the different event specs.
I may still be driving something at Superlap, so all is not lost.
I know Ian will be pleased, he can give my spot to one of the many people who would ring and hassle him daily I reckon ;) lol
Well i guess that only took 7 years :D
^^^ lol :P
What did Giant's R32 run at Willowbank years ago? 9 something, with shagged semis and circuit camber etc.... on low mounts. Oh, and only one full pass because they were thrown out due to a non ANDRA cage.
One must wonder what Berry's 34 would run.... I've driven the things and it's farking insane.
Hmmm wow.
On another note, I'm always interested to see how and indeed if the drag fraternity can get their cars to last even one fast lap.
The requirements of the car are very far removed from drag.
Spoken for truth. I often wonder at the mentality of those praising some big hp dyno queen or drag car tuner when all they do is keep them alive for seconds at a time.
Track work places far greater demands on a car than straight line/dyno ever will.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
    • okay, so I figured this out, removed needles and reinstalled after swapping the gauge face on my triple gauge for my ER34, all work and look good. I tried to do the same for the main cluster, but the main cluster gauge faces are dished, the replacement gauge face are flat, so due to the dish in the org face ,mounting backing plate (clear) and depth of the needle, the flat gauge face will not work. I notice that R34 gtr gauges are flat, appears to be different clear backing plate that aren't dished. are these available, or what have others done to install flat gauge faces?
