hey guys
I have a r32 gtr that i brought as a roller and i'm looking at a r34 v-spec engine with loom just wondering what are the differences?
will it bolt straight in?
will my r33 gtr gear box bolt straight up?
engine sensors or wiring differentces?
any help would be much appreciated
crank angle sensor is different between engines .
clutch will need adressing
eg use your r33 flwheel clutch and fork
front diff ratio is different . put r32 or r33 sump on the motor
hopefully someone with more knowledge doesnt show me up too much more
hey guys
Hi
From what I understand, cam angle sensor, engine harness, coil packs, cam shaft. Gear box I thougth would bolt up. Send me a pm with contact details I may be selling what you are after, already set up. I just need to make the choice to keep as back up or sell.
Cheers
the crank is different as well yeah???
but in terms of its physical attributes its the same engine (just newer tech etc) and will bolt in the same... i have a mate with an r34 gtr engine in his r33 and he runs an r33 gtr box....so u should be sweet
couldnt tell u about the diffs...
u should put this in the forced induction thread, it will get way more views buddy
