Hi there, i have some series one and series two parts for sale:
R33 series 1 coupe - front bumper $ 60 ( its no a type m or nothing just a standard bar, Good if you get a defect for clearance this bar is smaller, has some scratches )
R33 series 2 coupe - back seat side trims and the trims that go around the window ( complete both side) $90 ALL 4 (2 each side)
R33 series 1.5 coupe - passenger side gaurd complete with indicator and badge (white) $100
R33 series 1.5 coupe - drivers side skirt $50
R33 sereis 1 coupe - spoiler ( in undercoat) $ 50
R33 Series 1 coupe - boot and and spoiler (white) $130
R33 series 1 coupe - boot (candy red) $90
R33 series 1.5 coupe - rear boot lip ( its under coat) $70
R33 series 2 coupe - mirror complete but no glass (white) $30
R33 series 2 coupe - drivers side door complete with glass window motor and locks (white) $150
R33 series 2 coupe - passenger side door complete with glass and locks (white) $150 glass is not in the door but it comes with it. ( no window motor)
R33 series 1.5 coupe - center clear garnish. ( where it says SKYLINE) $40
R33 series 1.5 coupe - door trims with red vinyl inserts no bad condition (passenger side comes with window switch) $40 both
R34 turbo coupe - Dash board gauges complete (all 3 complete with cover) $180
R33/R34 - manual steering wheel with airbag $200
R34 auto steering wheel with buttoms (not bad condition) bit worn - $100
R34 Skyline - lhf mirror - $140
R34 Skyline - rhf mirror - $140
R34 Skyline - cluster with like 130kn on it. $150
Im in melbourne (northern suburbs)
If you want anything let me know, its better if you msg me 0434405366 ( as sometimes i dont have time to jump on the computer) thanks!!!
Edited by helrzr28
https://www.sau.com.au/forums/topic/347683-r33-and-r34-parts-for-sale/
R33 Series 1 coupe - boot and and spoiler (white) $120
R33 series 1.5 coupe - rear boot lip ( its under coat) $60
R33 series 2 coupe - passenger side door complete with glass and locks (white) $110 glass is not in the door but it comes with it. ( no window motor)
R33 series 1.5 coupe - center clear garnish. ( where it says SKYLINE) $35
R34 turbo coupe - Dash board gauges complete (all 3 complete with cover) $160
R33/R34 - manual steering wheel with airbag $190
R34 Skyline - lhf mirror - $120
R34 Skyline - rhf mirror - $120
R34 Skyline - cluster with like 130kn on it. $140
Im in melbourne, thornbury (northern suburbs)
If you want anything let me know, its better if you msg me or call me 0434405366 ( as sometimes i dont have time to jump on the computer) thanks!!!
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
    • I'm shocked, you've owned a Skyline since 2006 and never joined SAU before now! 😮   Welcome, it's much quieter these days than it was in 2006, but lots of very knowledgeable ones lurk around here. I actually think in outage we've forgotten more about Skylines than anyone knows about them today... 😛
    • So it could give us some info. Such as we find out what number they started at, and we know how many of those blocks came before it.
    • Everyone wants an ECU they can plug onto their engine, modified or not, and put of the box it just runs perfectly like a brand new modern engine straight off the production line. Too many people just don't understand things like the base maps are as you said, just to give a starting point, and then you need to spend time getting it right for your vehicle.   I wonder if the people wanting it are the same ones who'll just buy a chip for a "stage 2 tune" online and then wonder why their engine blew up...
    • Quite possible! And well worth checking out, as it will be more durable than paint
