Hey guys, well i decided i need to get around to getting this thing made. So im after someone who wants a cash job on welding up some framing that has their own welder and tools for cutting, bending some square tubing. It doesnt need to be professional but decent at least. if anyone is interested just let me know how much you think you'd do it for please.
Or if your a welder and can get a hold of some square tubing as well let me know a total price :thumbsup:
Something along these lines im after, thanks
So do you have the materials? Sounds to me like you are finally getting around to.... getting someone else to build something for you.. What have you already got exactly?
I don't see why anyone would have a bender (unless they are running their own business) as i don't know why anyone would have one for shits and giggles.. Sounds like you are looking at getting something on the cheap when they are able to be bought off the shelf.. This is ok if you have the equpment but i doubt somone will be willing to do a job on the cheap (especially at xmas) when they have a charge rate to pay equipment off, etc..
ps. after further looking at those pics.. none of them have bent sections.. why do you need a bender?
Edited by .:: GimpS-R34 ::.
mate, i would build it myself except i dont own a welder, and have never welded before, so i assume a home welder would be suffice. they dont need to be a professional either.
yeah i never really looked close at what i thought was a bend but it isnt so it wouldnt be needed.
i can either get the tubing myself, or if it was someone who could it cheap through their work and just wanted a cash job to do.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
