Unless they recorded unique part numbers its unlikely to yield anything TBH.
As for people hating, this ain't the wasteland listen to Madaz and "Do unto others as you would have done to yourself". Cos i know what u did last...... F*** it.
Little Johnnie and Tommy were playing at school , and Johnnie noticed a Rolex on Timmy's arm. Johnnie said "Hey, how did you get that Rolex" and Timmy replied "My parents were you know, doing 'IT' the other night and i happened to walk in. So my dad gave me his watch to leave then and there". This got little Johnnie thinking, and so he waited outside his parents bedroom night after night hoping to surprise his parents. Finally after waiting, on the fourth night 'IT" happened. So little Johnnie burst into the room shouting "Hey, I wanna watch!" And his father looked over at him and said "Ok, but stand in the corner".
I don't play games, i play life as its much more realistic.
...What?
  • Like 1
https://www.sau.com.au/forums/topic/347720-stolen/page/3/#findComment-5599376
Alright then, let me put my Moderator hat on and all joking aside.
WHOSE CAR IS THIS!!!
If it's not Cara's, then this thread is outta here cause we don't give a shit about Commodores unless they belong to a forum member.
So tell me how evil I am now Dohmar??
Well said. :yes:
https://www.sau.com.au/forums/topic/347720-stolen/page/3/#findComment-5600012
