If your that excited maybe just read through the thread.
The t67 with 10cm rear that Simon is running would be a great turbo for an RB30 although you will make more than 310rwkw pretty easily. Will you be running an aftermarket manifold and external wastegate?
I read the thread, got a tad confused with which model you were all talking about. just wanted reassurance on which one I'll be getting.
Will definitely be running an ext. gate, I'd love to low mount it on the stock manifold but from the looks of it I'll have to make a high mount manifold.
The stock manifold is not compatible with the turbo Simon is running.
The power he is getting exceeds the limit of the factory manifold and the turbo is too large to bolt on. You will need an aftermarket item like a 6boost or similar.
I'm not chasing as much power as Simon nor will I be using as much boost.
I would honestly be happy with 260kw.
But since these turbo's are all roughly the same price and I havn't started building the car yet, I may as well go big seeing as I haven't bought/made any of the supporting mods yet (injectors exhaust etc.)
what?
If you only want 260kw then get something smaller....
Hi there,
Could someone shed some light on these 3 turbos?
2.4
3.0
3.0W
I'm looking for a turbine for my GTST ... the turbos all have T3 flange, but the exhaust side is 5-bolt, not 6-bolt .. so it might not be a drop in replacement.
Also 2 of the turbines are only oil cooled ..
I have no idea of the boost response, so it's a bit of a shot in the dark ;)
Then get yourself a hypergear ATR43SS-2 or an ATR43G2 or even a G3
It will cost you comething like 1500, then you will need another couple of hundred dollars work to get it to bolt up. Get the supporting mods and you will have a setup that will make the power you want with as little hassle as possible and net great results.
The kando turbos are for people doing $5000+ turbo installs who would rather spend 800 for good performing turbos rather than $2000 on a garrett. The total cost is still going to be ALOT more than what else is available.
Consider:
Turbo 800
Manifold 1300 (new 6boost)
Custom dump 400 minimum
Wastegate 300 minimum
Custom metal intake 200
Custom hotside cooler pipe 150
Custom lines 150
Compare to hypergear'ing a R33:
turbo 900-1500 depending on what spec you want
exhaust utilies same position and bolt pattern as stock, so use whatever uve got at the moment (1000 will get you a turbo back system, if you have a catback then budget 360 for a bellmouth dump and 3" cat @180ea)
90 degree silicon joiner and a piece of pipe 50
The turbo would be on the car and running for the above cost. You could even just send him your stock turbo and get something back that will do 260rwkw NO WORRIES. Bolt it back in as it came out, as long as you have the supporting mods you just saved yourself the 3or so grand it costs to bolt one of the basic Kando turbos to your car.
It should be well known that while these turbos are fk'ing great, they are not bolt on items and will cost a fking packet to get on properly. The turbos themselves are excellent value for money, but thats only if you are comparing them to installing another external gate turbo, period.
Hypergear really does take care of most sub 300rwkw applications for an EXCELLENT price.
Agreed!
why cant you bolt the kando turbo onto stock manifold?
10mm spacer plate
adapt a 44/50mm external gate to exhaust housing and your done.
This was my original plan but it would need a lot bigger than a 10mm spacer as the compressor cover is fairly big. For me it was just easier and not that much more expensive just to run a 6boost manifold!
When you factor in the costs of long studs, specialized welding to exhaust housing, extra gaskets, the spacer itself etc etc it all adds up.
Exactly!
Plus your turbo out flows the factory manifolds effective limit.
If you went for the 20g-sl2 kando turbo, you could do what is being suggested and could potentially have HKS2835 like results, but hey you could spend a shit load less on a hypergear and still be doing pretty good and VERY stealthy.
Have we seen the recent addition to the kando range? A TD06SL2-25G 10cm T3 with surge ported compressor cover.... small trim 61mm turbine with small trim 78mm compressor, surge porting indicates we could have some SPOOL on our hands.... Anyone game to try a 3076R killer? Would need to be gated is the only downside :(
That is the same wheels as my T67-25g 10cm but with water cooling and a anti-surge front cover...
So I wouldn't imagine much of a difference at all expect only a 3" inlet instead of a nice 4"
The SL2 wheel is apparently the same wheel but cropped to 61mm instead of yours which is 67mm.
Sort of like the 30R that gets cropped to the 2835.
I'm a fabricator so I'd be making all of the custom pieces myself. so manifold/exhaust/intake/piping etc. is not really a problem....just a time thing.
But I'd like to retain the stock manifold if at all possible (with the new TD06SL2-25G 10cm T3 maybe?). I've made a mild steel manifold before but the time/effort/pain is too much.
I said I'd be happy with 260kw as in worst case scenario.
No two ways about it if you ask me, you are wasting your time with this turbo unless you get a manifold for it.
If that's how it has to be, I'll keep it in mind when I'm buying all the bits (turbo included). Thanks for the advice mate
No worries, its just that it significantly outflows the factory manifold... So running it within the limits of the factory manifold will get you sub standard results.
You would be better off with a turbo that suits the factory manifold and reap the benefits of added spool and response. Going interal gate also saves you a packet and isnt as cop bait.
There was some talk that the TD06SL2-20G 10cm T3 would be awesome for sub 300rwkw application but even then you need to plumb a gate and it starts to become questionable just how much better it might be than a hypergear bolt on item..
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
    • I might have gone a little more South Efrican.  But this is off topic.   😍😍 FD 😍😍
