TD06 SL2 25G, T67 or TD06H 25G ? as the first 2 are the same as far as i can see, some vary in comp covers
and the TD06H is always the bigger turbine as far as i can see in Kando speak, think that what was confusing Roy maybe, or maybe i am the one confused?, but it is confusing..lol
cheers
darren
Edited by jet_r31
Yeh i know they are different Roy, but i think the poster was refering to the TD06 SL2 25G that kando sell,,and they are the same, the comp covers
are only different
He will do this one
http://www.ebay.com.au/itm/270794579581?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
For $664 to your door this week if you pay through paypal
I want to buy tommorrow, not sure if i should buy that one, or this one
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-3-Anti-Surge-TD06S-25G-T3-V-Band-/290603882502?pt=AU_Car_Parts_Accessories&hash=item43a9575806
Thoughts??, i want to put it on a standard manifold. One just looks prettier from all i can tell, i don't need to turn the earth power wise, would be happy
with 320ish rwkw on a standard manifold,on pump 98 with water/meth injection hard to ignore the cheap one for the price though.
cheers
darren
Looks prettier ... ??
one has a much smaller comp housing than the other..on the TD07, the comp housing is huge and wont easily fit on your stock manifold so I'd say get the other one it should fit with a 10mm spacer
this one..
I I cant make sense of all the Kando turbos...in one part they are saying TD06S, the next part of the add they are saying TD06L2 etc?!?!?! To the best of my knowledge the TD06S is different to the TDO6H which is different to the TD06SH... basically in Greddy speak the commonly referred to:
- TD06-25G is the TD06SH turbine
- T67-25G is the TD06SL2 turbine
- TD06-20G is the TD06H turbine
From info I have collected over the years...
TD06h - 67 mm / 59 mm (12 blade)
TD06S - 65 / 55 mm (12 blade)
TD06 - 65 / 55 mm (12 blade)
TD06SL2 - 61 / 54 mm (11 blade)
H and SH are the same, just some people abbreviate it to H.
I think that they just made a mistake with the title of one of the listings where they called is a TD06S but it is actually an SL2 which they mention in the Spec's sheet.
Edited by D_Stirls
Got my motor running today. Kinaguwa looks good spinning finally.
Still waiting on cooler piping and cooler to be modified.
Nice! not long now to we see some results :D
are theese rubbish china turbos with a badge thats made in japan?
uselss post, why bother.
sooooo...recomended boost is 22psi, when you gunna turn er up battery...:P
I was so keen to keep turning it up until it stopped making power but unfortunately the injectors maxed and the 170000km old valve springs were beginning to fade :( I have been keeping an eye on some upgrades so it might happen one day if I get bored enough....
Also for the haters noticed the JPP 180sx runs one of these turbo's http://speedhunters.com/archive/2011/09/07/car-feature-gt-gt-jpp-180sx.aspx
I saw Luke Fink drive this thing up at WTAC and its insane!!
Nigel from ETS has also been running a Kando core in his SL2 for almost a year now http://engineeredtoslide.com/2010/10/turbo-in-a-can/
When is yours gonna be finished ARTZ????
Edited by battery
so whats the differance between theese and the genuine mitsu units? i only ask because we have a td06sl20g at work that has crapped the thust bearing, and to fix is over 2k but i see whole chra's for 500 dollars. whats the diff?
shouldn't be too long..
do you remember if the oil lines they supplied fit straight up?
Dave, I thought these are made in Taiwan from ex-Mitsu tooling.
Pretty much this.
Mitsubishi sell all their tooling once it passes its very premature useby date.
Means you get a lot of OEM quality bits around.
The box says made in Taiwan assembled in Japan. Yet I have pretty much established the whole operation is based in Taiwan.
The QA process seems to be good, out of a very long trail of successful products there are only a handful of failures. From what I have seen warranty has never been an issue either.
http://www.ebay.com.au/itm/Garrett-T3-T4-Turbo-RB30-RB25-RB30-Oil-Feed-Fitting-/350356170487?pt=AU_Car_Parts_Accessories&hash=item5192dae6f7
You need some like that. I took my line and existing fitting into a place in dandy on Bennett st and they sorted it out.
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
