TD06-25G is the big brother of the T67-25G
has the same comp cover and wheel with a bigger turbine
TD06-20G is smaller than a t67-25G by using the 20G comp wheel
then there is the TD06-20GL2 Which has the 20G comp and the same small turbine of the T67-25G
Hope you havent had too many beers when trying to work that out hahha
T67 is it what Simon has and no way will it fit low mount td06 is smaller
yeh I have a t67 on mine too, it goes like this in size from small to large:
td06l2-20g
td06(H,SH)-20g
t67-25g
td06-25g
Edited by battery
Well, my TD06-20G is not an L2. I had an L2 but gave it to a friend with my old manifold etc to try. There is an identical RB20 to mine running the same mani/gate and tuner - dyno but L2 and he made 0.5kw less then me on the same boost with almost the exact same response. Mine was actually a bit more responsive. So I dont think there is really a big difference between the TD06 and L2 version of the turbine. The L2 turbine is common with the T67. I am not sure about the TD06H, but i know my TD06-25G is actually a TD06SH-25G. Here are some pics of the TD06L2 vs the TD06SH
As you can see the TD06SH wheel is a lot bigger
If you need I can take some wheels of the T67-25G wheel on the weekend and also my TD06 wheel. My turbz are all Greddy/Trust jobbies but imagine they are all the same wheels, if not housings
Joel
Send your thanks to Roy
What is a little bigger than the td06sl2 20g and would fit low mount
The "non" L2 version might be able to flow a little more through the turbine, but as per Roys quote above there is SFA difference,
the issue with the T67 not fitting isnt the sheer size of them, but rather the much smaller turbine housing, a spacer plate could be made to suit, as the Comp cover is around GT3582 size, which does fit low mounted to a Rb25.
I would show you pics but some flamin mongrel stole my TD07 last year
isnt the problem that the stock manifold simply wont flow enough for a t67 to do its best...
Thats why i didnt bother with it..
Stao from hypergear said aftermarket manifolds reduced response and didn't increase power at all with his turbos around the 300kw mark.
maybe spend abit more and get a gt3076???
Thats what has to be weighed up, TD06 + ext gate and fabrication may cost more than an Internal gate GT3076 + dump
My case is different due to 1JZ needing a new manifold no matter what
Thats why i didnt bother with it..SL2 seemed like a better match..I can always hide a gate..
I tried to fit my t67 on the stock manifold just to see if it would fit but it was hitting engine mounts and A/C lines looked like alot of work and bordering on impossible.
Are you going to plumb the gate back into the exhaust?
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
    • Being a manual, we very quickly ordered new R34 gearbox (From Nissan) and remaining parts from Kudos motorsports. Would highly recommend the team there. Ultra helpful and quick to share advice and upgrades. We are in the middle of taking the Auto out (Genuine 94,000/kms) and putting the Manual in this weekend. Part 2 of the build will include likely a Plazaman Intercooler and Plenium, Hks Exhaust with Tomei Dump (ordered).
