TD06-25G is the big brother of the T67-25G
has the same comp cover and wheel with a bigger turbine
TD06-20G is smaller than a t67-25G by using the 20G comp wheel
then there is the TD06-20GL2 Which has the 20G comp and the same small turbine of the T67-25G
Hope you havent had too many beers when trying to work that out hahha
T67 is it what Simon has and no way will it fit low mount td06 is smaller
yeh I have a t67 on mine too, it goes like this in size from small to large:
td06l2-20g
td06(H,SH)-20g
t67-25g
td06-25g
Edited by battery
Well, my TD06-20G is not an L2. I had an L2 but gave it to a friend with my old manifold etc to try. There is an identical RB20 to mine running the same mani/gate and tuner - dyno but L2 and he made 0.5kw less then me on the same boost with almost the exact same response. Mine was actually a bit more responsive. So I dont think there is really a big difference between the TD06 and L2 version of the turbine. The L2 turbine is common with the T67. I am not sure about the TD06H, but i know my TD06-25G is actually a TD06SH-25G. Here are some pics of the TD06L2 vs the TD06SH
As you can see the TD06SH wheel is a lot bigger
If you need I can take some wheels of the T67-25G wheel on the weekend and also my TD06 wheel. My turbz are all Greddy/Trust jobbies but imagine they are all the same wheels, if not housings
Joel
Send your thanks to Roy
What is a little bigger than the td06sl2 20g and would fit low mount
The "non" L2 version might be able to flow a little more through the turbine, but as per Roys quote above there is SFA difference,
the issue with the T67 not fitting isnt the sheer size of them, but rather the much smaller turbine housing, a spacer plate could be made to suit, as the Comp cover is around GT3582 size, which does fit low mounted to a Rb25.
I would show you pics but some flamin mongrel stole my TD07 last year
isnt the problem that the stock manifold simply wont flow enough for a t67 to do its best...
Thats why i didnt bother with it..
Stao from hypergear said aftermarket manifolds reduced response and didn't increase power at all with his turbos around the 300kw mark.
maybe spend abit more and get a gt3076???
Thats what has to be weighed up, TD06 + ext gate and fabrication may cost more than an Internal gate GT3076 + dump
My case is different due to 1JZ needing a new manifold no matter what
Thats why i didnt bother with it..SL2 seemed like a better match..I can always hide a gate..
I tried to fit my t67 on the stock manifold just to see if it would fit but it was hitting engine mounts and A/C lines looked like alot of work and bordering on impossible.
Are you going to plumb the gate back into the exhaust?
