alot of plp say the cheapy ebay manifolds cause boost control issue, but lets wait and see what Jez finds out.
try changing to a stiffer wastegate spring as well.
hopefully it can crack 300 mark with E85.
dam if so, looks like it won't make near 300 on 98 :(
I was on my phone and didn't realize it it was at 12 psi
this may sound like a dumb question but how do i read that dyno chart JEZ i have only seen the dyno dynamics ones which seem easier to read i gather the very top line is boost but its still a tad confusing
Edited by luvpsi
I'll post before he does car feels wicked to drive very responsive. eBay gate is no good put my turbosmart gate on running 13 pound creeps to 15 great turbo. Jez can say the number it's just running gate pressure has a very fat torque curve kando you did it again
Edited by Bsa
No boost controller, 35mm turbosmart gate courtesy of BSA. Boost creep from 11-15 (need a 44mm gate) power and torque just kept climbing. And thats with a missfire from the coilpacks. Will get some split fires but for the time been im going to drift it on thursday before i do any more mods such as a bigger and better gate and a decent boost controller. I think with a flat 20 psi this thing will be even more insane.
I cant believe the torque didnt ever nose over,
Ok the top line is AFR
2nd line is power
3rd line is torque
4th green line is power kw
Sorry about the RPM i was revving to 7000 roughly.
EDIT: this is WITHOUT VCT. As i dont have a speed signal connected yet
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
