If somebody really wants to try this, the thing to do is email a request for a: TD06SL2-20g T3 10cm Internal wastegate with rear housing opened for use with 5 bolt or individual dump pipe, not single 3 bolt outlet and covered wastegate. wastegate to be uncovered.
What's wrong with a 3 bolt flange?
Sorry if something similar has been answered...
but im in the market for a turbo, want straight bolt onto rb25, and responsive 230-240rwkw
noticed they have a range of bolt on turbos for a 25, just not sure which one.
thanks in advance!
theres nothing wrong with a "three bolt flange" in general, but these particular internal gate turbos that have a 3 bolt flange only have a little 2.25" outlet (from memory) and the rest of the flowpath is blocked off.
Understand what I mean now? Im simply identifying the cruddy IW housings as a 3 bolt
thanks in advance!
Did u post this on ns.com, If so I replied there
thanks in advance!
i think this is your answer - http://www.digi-hardware.com/rb25t3hiflow.html
$960 (inc stainless oil lines) + postage. you cant really beat that.
be good to see someone give one of these kd gt3582's a go
http://www.ebay.com....=item416003bba9
That looks epic, I would totally want one of those. GCG do a 3566R which is pretty much the same thing, they do it for XR6Ts. I rekon that would be a cool turbo, worth a shot. Price is phenomenal too.
Guys, Eiji has told me they only have surge slot front covers ATM in sl2-20g. Any difference with these compared to non surge slot? Would it affect anything if I run this cover??
Shouldnt be an issue. AFAIK Minor edge taken off the spool is the only ownside, might not buck as hard onto boost.
3540/66's have been built by everyone since the dawn of time, fastest vl has run 9.2 at 147mph in a full weight calais on 38psi with one , mid's 9's is typical
Would be awesome for a cheap 3.0+ turbo, or 2 on a 5.0-6.0 V8....
They take a fair edge of spool with that big comp wheel aswell, its a fair bit of a mismatch.
Be interesting to see how the twin entry housing went with a 6 boost
cheers
darren
Edited by jet_r31
Oh yeh forget to add a few weeks ago, Willal racing used to, and still does on there street gtr i think, run twin TD06 25G's on the os giken 3 litre motors, think they made'upwards of
650rwkw, the car went 8's at 160ish mph in the end, i remember the street car made 470rwkw on 20psi on bp ultimate 98 back in the day and ran
high 9's at 144mph in street trim, i think its on E85 now with a lot more power
street car
Edited by jet_r31
    • Is anyone running these axles? R32, R33, R34 GTR front Axles. shafts itself rated 950hp. Suit all RB26 engines Croydon, Melbourne, Victoria Would be nice to pay half the cost of Driveshaft Shop Axles. I'm building an AWD S13 Coupe that is very low ride height (high cv angle) compared to stock R32. Has an RB30 with appx 600whp. Just looking for feedback. Thanks, Josh- https://www.instagram.com/feng_shui_garage/
    • Been a long time since r31 got some love, my brother dropped a shitbox ls1 crapadore in my lap to fix up.  Put a wiper motor in as the flooded one was no longer alive.  got windscreen wipers now. Time to clean respray and install back in the titanic  IMG_0505.mov
    • Nah its a server spammer thing  Although, now that I manually approve all the accounts I can probably loosen up some of the restrictions.
    • Thread bump, again! Although, no bad news this time. Posting for the sake of possible root cause. Basically, I rebuilt it (mostly stock), installed Haltech + sensors, had it running fine on new ECU.  Still not really understanding why it cracked pistons last time. Got to tuners, and while checking timing, noticed +-10deg of timing scatter while revving. Changed CAS, and it was rock solid. While not definitive, can't imagine seeing 20+ psi with that amount of scatter would be a good thing. Also glad I found something.   Bit more of a run down; Carried out a stock rebuild, a set of stock pistons, out of a spare bottom end. Everything stock apart from head studs and oil restrictors. (so I can pretend I didn't let the Nissan out, ha.) Armed with the measuring gear and FSM, set about doing overhaul. Oil restrictors as per oil control thread for a RB25, stock oil pump, drifting. Head drain/vent from rear of head, to passenger side of sump above oil level. Two dash 10 vent lines from drivers side of sump (unused atm) Hi octane style cam cover breather kit Splash covers over last 2 cam caps. Both breather lines from cam covers to vented to atmosphere catch can, not plumbed back into sump (wanted to see what it was actually breathing). Got it run in (did about a 1000km) no to low boost scenario, As I had questions over old ECU setup. Installed haltech +sensors for flex Retune on E85 (finding CAS Issue along the way), made 300rwkw at 20psi, out of wastegate. Did a drift day the next day (yes, it was a big weekend!) and was checking catch can throughout the day, ZERO blowby. I mean nothing. Lines from cam covers are not even wet. Done a bunch of street driving, spirited and catch can is still dry. Early days I guess, but pretty happy so far. Also now run 10w60, up from the 10w40 that I used to run. Oil pressure is significantly better, especially when hot (as you would expect)
