Hes taking his sweet time isn't he lol...
If someone wants to lend me a Kando td06sl2-20g and will pay for a tune ill be happy to take my T67 off and give it a try in the name of science!
LOLz...had alot on man, end of year is always busy for me...Also just got bak from marathon trip around the snowys and blue mountains.. and a bit of QLD..done over 3500kms in the last week..
and while On the subject I must say the NSW mountain roads rock, they shit all over VIC offerings :(
Also dodgey ebay injectors were dodgey..flowed at 300cc...f**kin, applied for refund and have dodgey ebay guy threatening legal action cause apparently I'm lying, interstingly its f**kin hilarious in a "I want to smash you flamin mongrel" kind of way...Anyway turns out the guy who tested them for me had some 555 nismos so will get them instead..Adaptronic is here, that had scrathes on it too, kind of weird for a brand new item but looks ok..
then I want to tap an IA sensor into my intake, etc etc cmon guys you know what its like.
Anyway enough of my excuses... :whistling:
LOL @ true blue rip off artist, flamin mongrel!! or was that the forum correcting a c u next tuesday comment? LOL
Where did u buy the adaptronic man? disappointing to hear it came with blemishes :S I assume you bought it new....
yeah its new ,had some little scratches on it like someones tried to jimmy it open..weird..
the injectors were tested side by side with some stock nissan ones, I guess they are sr20 ones or something and they flowed identical..cant say i wasn't warned :/
guy had a great trader rating so not sure what his game is as yet...time will tell.
Now that one is interesting... That could be a good 350kw turbo (not sure if it would be better than a T67 though..)
Kando has some good stuff rolling out :S
Yeh unfortunately without any real testing back to back its just a guessing game........
cheers
darren
Edited by jet_r31
Ok so i finally sold my hks2530 ready to purchase a kando td06sl2 . My setup is going to be:
rb20det (seems rebuilt or very very healthy)
gtr 444cc injectors
gtr cooler
power fc
z32 afm
full 3in exh (with high flow cat and de-cat for track)
hks 40mm ext gate
gtr fuel pump
ok my questions are : i have r31 rb20det cams laying about , would these be worth chucking in? , secondly , fuel . In tas we have 3 options of 98 , 1 bp ultimate ,2 caltex , 3 united (ethanol) . Do you guys think it would be worth trying the united 98 over bp? (caltex is the most common but i've heard stories of it not being very good quality)
gtr 444cc injectors
gtr cooler
power fc
z32 afm
hks 40mm ext gate
gtr fuel pump
No to cams, don't bother!
E85 is heaps better than 98, but you will be out of injectors and fuel pump pretty quickly :)
Ok , cross cams off my list . No E85 at servos in tas :( , i could order it in drums but i didn't think the fuel pump or injectors would be able to keep up
Which united has 98 Toff? BP ultimate is probably the mokset reliable but obviously quite a rip off, calted just add octane booseters to their 95 to get it up to 98 so its not as high quality as the ultimate
Yeah i've been running my r34 on it for a while :)
gtr 444cc injectors
gtr cooler
power fc
z32 afm
hks 40mm ext gate
gtr fuel pump
bought this: http://www.ebay.com.au/itm/270877815374?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_2526wt_503
I'm going to get it tuned on united 98 (unless someone can give me a good reason not to ) , Will let y'all know how it goes :)
http://www.ebay.com....=item3f11b64fb1
Anyone post that one up? Gt3582 comp wheel with 11 blade TD06h turbine with .73 T3 housing.
I'm really curious about these also. I'm currently waiting on a price to strip, assemble and balance my old hypergear GT3576 with a KD 3582 compressor wheel and cover kit. Depending on what the Perth thieves I mean professional turbo workshops charge me. I might end up buying 1 of these.
I would love to see(work out) what would make more power and be nicer to drive on my RB30 between the KD 3582, TD06H-25G or even a 10cm T67
It all comes down to your goals mate. Be it myself I would probably go a T67.
IMHO It will go like a shower of shit. Probably hit peak torque very early and wont need to rev it very hard, however without E85 I dont see it doing over 350kw (as a sheer maximum, it may not actually hit that either).
My second option would be the TD06H-82 hybrid (3582 compressor on TD06H rear). My guess is that this combo will be something like a 'GT3282' or 'GT3240'. My guess would have it more responsive than an actual 35R with a similar power threshold. I would love to see this one in action.
I'm hoping someone here will be able to give me some advice. I know its a Skyline based thread but information on these with use on a rotor is very limited to non existent.
I have a FD3S (13B-REW) and the twins are very much on the way out. I have been looking at one of these as a potential single option.
I have it down to the following -
T67-25G 10cm
or
TD06H-25G 12cm
Being a rotor I am leaning more toward the TD06H as it has the bigger rear. Looking at the TD06 kits Trust supply they seem to use a 16cm rear.
The goal for the car isn't massive power, it currently makes about 300-310rwhp with the twins in non-sequential setup (fairly laggy). I guess I'd like a little more power. Say aiming for 380-400hp?
Some thoughts on the above?
Edited by mr_squiggle_1
I think rotors want the big rear housing or big turbo.. These are more small housings aimed at 4 banger type setups (and being exploited by us 6 pot guys).
You could run one but I think you will be capped, you should probably look at a PT6262 or something like that.
Otherwise the twinscroll 3582 variant Kando does may suit you :thumbsup: its towards the top of page 90
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
