Hes taking his sweet time isn't he lol...
If someone wants to lend me a Kando td06sl2-20g and will pay for a tune ill be happy to take my T67 off and give it a try in the name of science!
LOLz...had alot on man, end of year is always busy for me...Also just got bak from marathon trip around the snowys and blue mountains.. and a bit of QLD..done over 3500kms in the last week..
and while On the subject I must say the NSW mountain roads rock, they shit all over VIC offerings :(
Also dodgey ebay injectors were dodgey..flowed at 300cc...f**kin, applied for refund and have dodgey ebay guy threatening legal action cause apparently I'm lying, interstingly its f**kin hilarious in a "I want to smash you flamin mongrel" kind of way...Anyway turns out the guy who tested them for me had some 555 nismos so will get them instead..Adaptronic is here, that had scrathes on it too, kind of weird for a brand new item but looks ok..
then I want to tap an IA sensor into my intake, etc etc cmon guys you know what its like.
Anyway enough of my excuses... :whistling:
LOL @ true blue rip off artist, flamin mongrel!! or was that the forum correcting a c u next tuesday comment? LOL
Where did u buy the adaptronic man? disappointing to hear it came with blemishes :S I assume you bought it new....
yeah its new ,had some little scratches on it like someones tried to jimmy it open..weird..
the injectors were tested side by side with some stock nissan ones, I guess they are sr20 ones or something and they flowed identical..cant say i wasn't warned :/
guy had a great trader rating so not sure what his game is as yet...time will tell.
Now that one is interesting... That could be a good 350kw turbo (not sure if it would be better than a T67 though..)
Kando has some good stuff rolling out :S
Yeh unfortunately without any real testing back to back its just a guessing game........
cheers
darren
Edited by jet_r31
Ok so i finally sold my hks2530 ready to purchase a kando td06sl2 . My setup is going to be:
rb20det (seems rebuilt or very very healthy)
gtr 444cc injectors
gtr cooler
power fc
z32 afm
full 3in exh (with high flow cat and de-cat for track)
hks 40mm ext gate
gtr fuel pump
ok my questions are : i have r31 rb20det cams laying about , would these be worth chucking in? , secondly , fuel . In tas we have 3 options of 98 , 1 bp ultimate ,2 caltex , 3 united (ethanol) . Do you guys think it would be worth trying the united 98 over bp? (caltex is the most common but i've heard stories of it not being very good quality)
gtr 444cc injectors
gtr cooler
power fc
z32 afm
hks 40mm ext gate
gtr fuel pump
No to cams, don't bother!
E85 is heaps better than 98, but you will be out of injectors and fuel pump pretty quickly :)
Ok , cross cams off my list . No E85 at servos in tas :( , i could order it in drums but i didn't think the fuel pump or injectors would be able to keep up
Which united has 98 Toff? BP ultimate is probably the mokset reliable but obviously quite a rip off, calted just add octane booseters to their 95 to get it up to 98 so its not as high quality as the ultimate
Yeah i've been running my r34 on it for a while :)
gtr 444cc injectors
gtr cooler
power fc
z32 afm
hks 40mm ext gate
gtr fuel pump
bought this: http://www.ebay.com.au/itm/270877815374?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_2526wt_503
I'm going to get it tuned on united 98 (unless someone can give me a good reason not to ) , Will let y'all know how it goes :)
http://www.ebay.com....=item3f11b64fb1
Anyone post that one up? Gt3582 comp wheel with 11 blade TD06h turbine with .73 T3 housing.
I'm really curious about these also. I'm currently waiting on a price to strip, assemble and balance my old hypergear GT3576 with a KD 3582 compressor wheel and cover kit. Depending on what the Perth thieves I mean professional turbo workshops charge me. I might end up buying 1 of these.
I would love to see(work out) what would make more power and be nicer to drive on my RB30 between the KD 3582, TD06H-25G or even a 10cm T67
It all comes down to your goals mate. Be it myself I would probably go a T67.
IMHO It will go like a shower of shit. Probably hit peak torque very early and wont need to rev it very hard, however without E85 I dont see it doing over 350kw (as a sheer maximum, it may not actually hit that either).
My second option would be the TD06H-82 hybrid (3582 compressor on TD06H rear). My guess is that this combo will be something like a 'GT3282' or 'GT3240'. My guess would have it more responsive than an actual 35R with a similar power threshold. I would love to see this one in action.
I'm hoping someone here will be able to give me some advice. I know its a Skyline based thread but information on these with use on a rotor is very limited to non existent.
I have a FD3S (13B-REW) and the twins are very much on the way out. I have been looking at one of these as a potential single option.
I have it down to the following -
T67-25G 10cm
or
TD06H-25G 12cm
Being a rotor I am leaning more toward the TD06H as it has the bigger rear. Looking at the TD06 kits Trust supply they seem to use a 16cm rear.
The goal for the car isn't massive power, it currently makes about 300-310rwhp with the twins in non-sequential setup (fairly laggy). I guess I'd like a little more power. Say aiming for 380-400hp?
Some thoughts on the above?
Edited by mr_squiggle_1
I think rotors want the big rear housing or big turbo.. These are more small housings aimed at 4 banger type setups (and being exploited by us 6 pot guys).
You could run one but I think you will be capped, you should probably look at a PT6262 or something like that.
Otherwise the twinscroll 3582 variant Kando does may suit you :thumbsup: its towards the top of page 90
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
