Hey SimonR32,
As little as possible :whistling: But probably 7500. My 25 used to make 430hp@7400 and still make power on the way to 8000 but i didn't like revving it that hard. I should post up a dyno graph as its interesting to compare it to your T67 result on E85. Actually your graph was what convinced me to go T67!
In a nutshell 3037 in front until 3500 from my hazey memory from last night while i was trying to digest all 90+pages... but after that the T67 romps away :thumbsup:
Do any of you guys with the T67 have a torque graph you can post- I don't care about the numbers or scaling, i'd just like to see the shape of the curve?
DVS JEZ- i run -5's on the 26/30 in my GTR. Just awesome. Its in the shop now for it's final tune...before i sell it :( to provide me with some more fun tickets so i can finish my little track car :D
The 6boob jobbie really does make quite a difference- i picked up 30hp while dropping 2psi on the 3037!
BTW the 26 is going in my S13
8000rpm minimum on a RB26, I think that's even stock... If it's built well 9000rpm shouldn't really be an issue either!
Torque Graph:
Yeah the internal gate one they do comes in an L2 rear, might be worth trying.
I had the crazy idea that this one would be better though:
www.ebay.com.au/itm/Turbocharger-SR20DET-SILVIA-S14-S15-TD06SL2-18G-Turbo-/270893185830?pt=AU_Car_Parts_Accessories&hash=item3f127dfb26
The TD05H-18g has about 280kw in it with a 10cm housing, maybe the L2 rear in that one will free it up even if its a 8cm.. Thats my thoughts anyway.
Bro can you PM me a price to put a gate adapter on a stock manifold, cut and shut my dump and weld on a screamer? Seriously thinking about a kando again lol
Simon,
I was being facetious- sorry. It'll rev to whenever it stops making useful power. That said, yes built balanced blueprinted etc etc. But i will probably stop around 8000. I remember when Gibson motorsport stopped revving them past 7000 towards the end of the Group A era, i don't remember the exact figures, but engine rebuilds went from a a few hundred km's to into the low thousands.
I'm not chasing every ounce of power, solid performance & reliability is my goal.
Thanks for the torque graph.j I'll scan my 25 printout tomorrow as a comparison and post it.
Doing the dame thing for dori34 this sat
blakes work is sexy and he knows it..
very happy with the way he done my mani job :D
GTScott, Just go with the kando man! everyone says how brutal they (and the trust series) are on boost, i cannot wait to experience this myself.
kekeke, just need to keep control of det on my setup.. remember its sitting on 10:1 CR and i dont really want to decompress it
if i can find evidence to support that ill be fine ill probably look at getting a TD06SL2-18g 8cm T25 and get Blake to hook up a gate for me and mod my dump.
Here is the 3037s graph showing torque and power. The pink run was the original turbo, the red one was after it was rebuilt by GCG.
Look for a faint pencil line, that is SimonR32's run on E85. It shows T67 a little behind the 3037 until 4500- there's nothing in it so you can say they are roughly the same- after which, the T67 walks away.
Both my runs are at 19psi
I know i said mine made 430, it did, this was re-tuned after i plumbed the external gate back into the main exhaust which lost some power in the top end - not shown in these graphs.
Why if only running a 2L would you want to run the bigger turbine and associated lag of the TD06? Especially if you are only flowing the lbs of air from the smaller 18G compressor?
Any change of a bigger dyno? cant see anything :)
If you attach the full size it will shrink it down for normal view then you can click on it to see the full image.
Its only a smaller trim compressor, it should breathe easily through the L2 rear. I want to keep my rear side fairly free flowing because I have the little 10:1 issue to keep in mind.
I consider this: if a td05h 18g 10cm can do 280kw, a td06sl2 18g 8cm with an external gate should be able to match it. hopefully the 8cm vs 10cm can match in spool also.
On the same token is Eiji could make me a T25 10cm TD05H-18g I would go for it :)
Yeah can't see shit! But if you want to compare a GT3076R (same as HKS 3037) with the T67 see this post
And here is a comparison of a 3076r with the same fuel, on the same dyno on the same day... Mine runs a little more boost, but this one has tomei poncams
Am i missing something re the compression of your motor? Compressor wheel gives you certain cfm of air. The engine makes a certain amount of hp with that airflow. The compression ratio doesnt increase or decrease back pressure or flow. It influences where you make your power and the amount of ignition the engine can take.
So not sure I would agree that because you have a higher compression you need to run a bigger housing.
OK more or less the same CFM of air (with a resultant HP) will have a higher EGT with the higher comp.
The TD05H-18g Jez tuned for me recently on a 9.5cr motor would start pinging once we hit 16ish psi. Pulling timing wasnt helping..... I have a feeling the 8cm IWG TD05H was just a shit balance when driving a big compressor on a high comp motor. It comes on boost very early and strong, just didnt want to take the boost.
It did make 207rwkw @ 15psi on a Mainline dyno, but hey we wanted more :whistling: It did not appear to be an issue with the way it was being tuned as I was on site watching timing and fuel trims being altered to combat the ping.
well i have decided on the T67-25G
will be putting it on a 6boost mani with either a turbosmart ultragate 45 or tial 44mm gate laugh.gif
just have to save money over the next 6-12months but ill be buying turbo first in the next 2 months so i don't change my mind
You can thank photobucket for resizing it, I'll have another go tonight when I'm home.
Are they both on E85 or 98?
Both on jew mix, 50% E85 and 50% BP98
Which is the T67 and which is the GT30R?
T67 is the slightly lazier 480rwhp and the GT3076R is the 436rwhp
Edited by SimonR32
    • 65601-05U00 is the hood latch. 62550-08U31 is the support that holds it to the radiator core support. They are all super discontinued so I don't really have any great leads on how to source this stuff.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
