Now lets see them do a billet 16g and whack it on a TD05H rear end.
I find it strange now that we had always discussed the TD05H and 20g being a mismatch, but FP are using TD05H rears with their HTA compressors which are meant to outflow the 20g - thoughts?
I am considering buying an FP Green with the 44mm WG outlet on the evo 3 style exhaust housing. Then order an SR-MHI 6boob and go spastic
heres some piccys for you to have a gawk at... :woot:
how she sits..
I gave the intake pipe a scrub, then painted it black.. :ninja:
And the dumps, dumps into a twin HKS pipe, Scotty doesnt like my design, he wanted to build me a whole pipe but i reckon it will work alright,
if it doesnt I guess he will get his way .. :dry:
some things I have wondered should I have done differently...maybe 3.5 inch dump..and tempted to just stick a 4 inch intake pipe with pod as well...not sure if there is much to be gained though
Mines all ready to go..all I need is a silicon joiner for the turbo outlet (which is on its way) and a bung for an unwanted hole in my fuel rail...then put it all together properly..everything has been test fitted..
Scotty likes to lobster, I like to let him.....Screamer is close to the dump, maybe I should poke it through the bonnet :P
I need to plug my adaptronic in and attempt to rough tune it..but this can be done on my laptop..then hopefully I can fire it up this weekend :thumbsup:
3" is plenty with a venting gate, mine is only 3" and handles a lot of power. 4" intake isn't really needed, just make sure you have a good K&N 3" filter :thumbsup:
screamer looks pretty close to the dump, might just be the angle of the photo tho.
And? Doesn't really matter :)
Finger crossed for good results ARTZ, E85 or BP98? Who is tuning?
Also don't skimp on the graphs, we want boost, torque, afr and power :banana:
Edited by SimonR32
^^^LOL you build it on a poor man with kids budget and get back to me on that....
Yeah i forget the gate venting seperatly..should be fine
E85 or BP98 is the only choice I have to make actually...cant make up my mind on that..both a are plentiful but I do like to go for long drives..
Plus if I tune for 98 I still have something to look forward to later..But yeah, really undecided still..
Trents gunna tune it for me..
Don't u have a data Logit thing? Get Trent to do tunes for both e85 and bp98!!
    • Welcome back to the scene! Godzilla Motorsports were well regarded back in the day.  My GT-R had work done there prior to my ownership.   SRS (Street Race Solutions) in Toowoomba worth a look.  They've built some pretty wild Skylines. Their YouTube channel is comedic to watch!  I'm sure they're all on the glass BBQ but they get shit done! 🤣
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
