Looking at SR20s running T518Zs there arent too many making 260rwkws on pump?!?! 240-250 seems more the norm.
230-240 is about right for the T518z on pump. Like you say 260 is a pipe dream :P
i just had issacs S15 come from racepace where it made 250, it made 239 on mine.. pretty direct comparo i reckon.
Thats great to know for the sake of the charts you are posting.
You must be kidding if all you want is 260kw from an 18g on E85 lol...... Trent has already said 280 on a 10cm in this thread, and I think he was referring to 98 ron.
Also, my car makes 275 on United 100RON, simply cant take the ignition of that tune if I run 98 so it drops to 260rwks on 98. I personally dont like my chances of the same tuner, using the same dyno going to a smaller turbo from the same manufacturer and making the same power. I stop increasing boost when it stops making power. I get more mid torque with a few more psi but at 19-20psi there isn't much more to be had. I mention that as well to highlight its not going to be likely that I simply run a bit more boost on the smaller turbo to make the same power.
I really don't know how much peak power I am going to lose going to the TD05H-18G....but I feel I may only get back to my 20G power figure with a 50/50 E85. Would love to be the idiot who has got it all wrong and am now going to make the same power with a TD05H-18G as I do with a TD06-20G (Both 8cm housings) :whistling:
Did another t67 on std rb25 sat with an adaptronic, made a lazy 305rwkw on pump @ 17psi
Specs and graph?? :)
Sucks having a turbo sitting there and nothing to bolt it to... Other people's results keep me going :P
Trent I recall you saying T518Z is 240-260 on 8cm and 260-280 for 10cm........ Has this since become a pipe dream? lol
I have only seen the one result with a T518Z 10cm on an SR20 so basing a conclusion on one car is pretty dangerous...but it appeared to offer less power than a 20G but with the same lag. So why not run a 20G and have the same drivability and make more power? I suspect that only finding one result which wasnt encouraging is the reason there are not plenty of cars out there running such a setup?!?!?! It simply doesnt work well?!?!?! >_<
I ended up going 8cm on my TD05-18G as you cant be all things for all occasions. I accept that if you go to a TD05-18G then you are going to gain response and lose power. Going to smaller turbine/compressors for response then putting bigger housings on them to make power doesnt seem to work as good in practice as it may in theory.
Have to say I agree :(
Am now trying to source a .64 GT28 housing for my 28RS..... The whole element of rapid that I pursue is far from what I have
we are seeing less and less of the 8cm making over the 250 mark nowadays, whether it is fuel or combo related im not sure (i would rather under qoute and over deliver). Have just done a 10cm which was happy as larry @ 270 with easycams.
Yeah T518Z 10cm gives l2 type lag without the top end or mid range torque.
lol i'm still none the wiser about what to get :(.
Sorry mate, being a higher comp motor you will want something with some leeway.
While the L2 10cm will be fine, you may not hit the mark in terms of 300kw. Lately I have found 98ron has been letting me down on DE+T builds (ive done a few).
Be it myself wanting 300kw from a 25+T I would definitely look at a hypergear G3. It will make the said power goal and wont give you headroom issues in terms of restrictive housings or small compressors. Sometimes I find a higher comp motor to be more sensitive to wheel combos, but am pretty confident in the G3.
Plus the G3 is bolt up to stock manifold and off the shelf dump, no bloody external gates or anything of that sort :thumbsup:
Is it wise to throw a turbo on an NA motor that isnt running E85? Surely it makes more sense to just buy a thicker head gasket and set the CR to a more turbo friendly level?
Ive been running a DE+T for 3 years at 220-240 on the standard hypergear highflow with plenty of track, skidpan, drift and daily duties on 98 and its fine, Can be a little prone to detonation on a hot day and doesnt take much in the way of timing with 98 when you start trying to wind in some good boost (I can only run about 15-16psi) that could be due to the shitty OP6 rear housing choking it up though
If you are wanting 250+ I would highly reconmend going e85 or WMI to keep the temps down.. Ill get around to doing these things one day this year
My first ever DE+T build is into its 7th year of abuse. Cant say Ive ever used E85 on anything other than trying to fudge an emissions test lol.
Have since built 3 more, all going strong also. Meh?
Bet your spewing you didn't Refresh that s15 motor oh well mine now
lol you need to come around and grab it mayne, its here waiting for you. No regrets tho, my issues are in my big rear housing more than anything else. I need that casheeesh! But no rush its here when your ready
    • Welcome to the new year, gang! We've ticked over into 2024, so as usual, we're starting the new year with a chill social out at Aqua Golf! So without any ado, here are the details: Date: Saturday 22nd March Location: Aqua Golf - Penrith Panthers Time: 4:00pm Map: http://tinyurl.com/saunsw-aquagolf All you need to do is bring yourselves down to Penrith Panthers to come and say "HI", hang out, and maybe hit a few golf balls at the drive range. Who knows where the night may take us... What we do know is that there are plenty of food options available at the Penrith Panthers complex. For those of us keen to hit a few golf balls, prices start from $7.00 a bucket. Aqua Golf is open til late, so we have plenty of time to have a few hits and laughs with each other! This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks all! Looking forward to seeing you all there!
    • Kicking off our first Sunday Session for 2025, we'll be heading to the delectable Self Raised Snack Shoppe!! Get your tastebuds ready for a mouth-watering toastie and coffee! As always, this is the best place to meet up with the SAUNSW fam for a coffee, bite to eat, and a chat! So what are you waiting for? Block out the calendar, set your alarm in the morning, and come down to hang out with the SAUNSW fam! Date: Sunday 9th March Meet Location: Self Raised Snack Shoppe - Shop 4, 8/20 Sarsfield Cct, Bexley North NSW 2207 (carpark entry via Slade Road) Meet Time: Meet at 8:00am Map: https://tinyurl.com/saunsw-selfraised This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Pre-empting heat management  1. The Kraken manifold will be ceramic coated 2. Just purchased some peel and stick heat shielding stuff from car builders, I'll cover some of the firewall behind the dump and a little on the cam cover, this will be done prior to installation as I have ample room to get where I need to now before that realestate has more bits in the way, I'm also planning to modify the OEM heat shield to go back on, but that won't happen until after installation so I know where to hack it up, I'll also cover it with some some peel and stick to neaten it up after the hacking 3. As the dump is stainless with a flex joint coating isn't really a option, and wrapping isn't recommended for a stainless dump, so once it is installed I'll grab some shielding from car builders to cover the dump, as it has some stand off, it "shouldn't" cause any issues and it "should" just keep the radiant heat away from " melty engine bay stuff" Not for heat management, but I've grabbed some more black crinkle coat to paint all the shiny intake pipes, I'll pick the pipe work up prior to installation and use the paint booth and big oven at work to cure them, I'll then wrap them with some bubble wrap so they stay nice during installation
    • We're back on, gang - Our yearly pilgrimage south to our favourite cafe for an awesome brekkie! Yes, that's right... we're heading down to Austi Beach Cafe for a breakfast run through the Royal National Park! Before you drool over your phones/keyboards, here are the details: Date: Sunday 23rd February Meet Location: Loftus Oval Carpark, Royal National Park, Sutherland Meet Time: Meet at 7:00am for a 7:30am departure Destination: Austi Beach Cafe, 104 Lawrence Hargrave Drive, Austinmer Map: http://tinyurl.com/saunsw-austicruise  RSVP: If you are planning to sit and have breakfast with us, please let us know, either by posting in the event, or by messaging us direct so we can confirm numbers with the venue. Itinerary: We will meet at Loftus Oval Carpark which has plenty of room and is low car friendly. This is a quick turn into the Royal National Park and some nice roads and scenery. After Stanwell Tops we will turn off and head onto the awesome Sea Cliff Bridge. Following this it is a short trip to Austi Beach Cafe. There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • YO- have been searching and searching for an a31 chassis plug pinout, or someone who knows which wire is for tach.  ceffy was flooded past dash during a hurricane.  having an electrical gremlin appear. tach is wonky reading consistent with a short, and on occasion the right side of my speedo lighting will flicker just for a second then go back to normal.  if no pinout available does anyone know if the tach harness opens or branches anywhere behind the dash? im suspecting a possible root behind the radio as there are more shorts in that area on the accessory loop.
