lol i wanna make that track day before the rego expires dude, i need to be able to fill it up wherever and whenever, jerrys just dont cut it!
Im seriously struggling to find elbows for the T28 at a decent price... might just get the .64 housing for the disco afterall (its cheaper in the short term)
AWESOME!!!
jez, remember to do a dyno run with and without VCT please if u get the chance :)
i want to see if it really does make a difference.
alot if run up on the dyno properley... spent hours with cam gears on numerous occasions trying to fill the void from no VCT.
cheers for clearing that up Trent! would you have any idea why theres a tapping noise when VCT is engaged? my tuner rekons its slightly touching the piston?
jez how did it go last night?
Roy: the billet wheel looks interseting,
how much did your one set you back? i wouldn't mind upgrading to a billet wheel if it is proven to give gains and worth the $$ spent.
Totally, no idea why people still aren't totally convinced when a lot of people (including Nissan) obviously swear by it. Proof has been posted and lots of credible people have stated time and again that its well worthwhile, it should be as clearly defined as is the fact that a turbo helps our cars make more power and torque.
<edit: Sorry, missed you had already responded - but still, VCT fully makes a worthwhile difference, I've seen ~10% gains for reasonable portions of the rev range by tuning it properly... and a couple hundred rpm or so improvement in spool>
And yes, how did it go Jez?
LOL WOT
Ask your tuner if he has ever dismantled an engine... VCT ventures down and decides to visit piston.. Hello piston, I am VCT.
If the tuner literally thinks that when VCT is engaged that the valve timing is causing the valve to make contact with the piston than you have a serious issue. You should have lost compression on all cylinders in that case. Devastating result.
If our VCT is noisy when it is engaged then you will need to test 3 things: is power/signal constant to VCT or inconsistent causing it to flicker on/off? Using stethoscope type tool listen to: VCT solenoid and see if thats the noise OR try to listen to cam actuator and see if that is the noise.
If the signal to VCT is constant when engaged and it is clicking away, either the solenoid is rooted or the actuator. If the signal is inconsistent the click could be the VCT constantly disengaging and re engaging, which would be an electrical issue. Then again if the solenoid was electrically screwed it could also have high resistance causing the signal to trip out and then try re engage etc.
Back to the drawing board.
LOL WOT
its a tapping noise, not a clicking noise that a vct solonoid makes.
he doesn't want to run it anymore with it engaged incase it causes major issues to the engine.
so really just looking around if anyone has had this issue and if theres any solutions for it.
want to know what im up for before and if i do decide to rip the head apart to have a look.
quite funny that the first tuning place who installed my ecu and put the run-in tune in did not pick this up or advise me of the issue- love their tuning capabilities (if they even did a run in tune!)
my comments still stand regardless of if its a tapping or a clicking, if its a tapping its more likely to be mechanical than it is electrical and again more likely to be the cam actuator more than it is the solenoid.
have you got a spare VCT cam gear (actuator) lying around to give it a go?
I just think its nonsense that the VCT engaging can make the valves hit the pistons. Unless the cam timing is out.
cam timing isn't out, he double checked it when he thought that was the initial issue.
he confirmed the noise was coming from inside the motor and not around the solonoid or cam gear area but willing to swap the cam gear over to try it out.
narh i dont have a spare VCT cam gear, is the cam gear from a r33 rb25 same as r34 rb25 neo?
anyone willing to lend me one to borrow so i can test?
Ok no Dyno for me :(
Lets just say DO NOT BUY A vband to 38mm wastegate adaptor cause there is no way to bolt it on and fit the v band or visa versa. They havent allowed enough room, i only had an hour this arv before i was heading to the dyno and didnt have enough time to pull the manifold off to fit the v band. Ill replace the gate next weekend.
DEVO
Added 15kw in the midrange for me, pretty huge improvement.
So I am trying the FP Green 73HTA compressor on my TD06L2 turbine and 8cm housing. Who is going to give their TD06L2 to ATP in Melbourne for one of their billet wheel upgrades?
I am waiting for a reply to my email at the moment. Real keen to see which of all these turbos makes the numbers or whether all their claims are hype.
Here is the claimed difference between their billet 20G wheel replacement (anodised Gold) and the std 20G compressor.
The above is on an EVO so you could almost add 30-40rwkws for an indication of what it would make on a Skyline
The claim that they also make 30kws more then the FB Green compressor which is a little alarming since that is what I have :( The wheel looks as close to identical to the BBK billet compressors only gold vs blue.
I would if i were a little closer to actually fitting it , my setup is fairly similar to yours so results (assuming dyno are setup similar) would be comparable . Or are you looking for someone to lend you their turbo for you to use in your comparo?
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
