Question for Trent (STATUS):
Do you believe the example shown for the 2871 vs L2 10cm to be acceptable as a 'rule of thumb' expectation?
The results you gave showed the L2 was just as responsive as a 2871 (am asuming .64 rear) and when the 2871 capped off at 250kw the L2 kept going to 300....
Am tossing up if I can expect the same from my own basic SR setup if I was to do a T3 10cm L2-20g with a decent manifold and gate.. The 2871 isnt too laggy when setup right (IMHO) but I am scared of how horrid a 10cm 20g might be on a stock SR.
Input would be highly appreciated :)
can you post a link the comparos? i get hit in the head alot cant recal that comparo :P
you do realise that if u get a ext gate kando turbo, factor in cost of gate/modding etc still ends up being cheaper then a hypergear.
More or less the same mate, depends if u got a great fabricator who is not going to rip you off? Who did yours? I also need to mod my dump flange from bellmouth to circular v-band - don't know if its possible/works great.
Or just sell your bellmouth dump pipe and get a completely new custom dump pipe made? I dunno about over there, but the best in the business here did mine for 350 bucks. You could easily sell your JJR dump for $200ish and then it's only gonna cost you another 150 or so and you have a dump pipe that is most likely going to work a lot better than a modified JJR one.
Unless you're worried about potential defects, I don't see why you're so against going external gate when it's plain and simple better and it's going to cost a bucket load to do.
The reason being I do not wana leave my car at any shop for more than a day ( I know it can be done in a day by a gun fabricator/mech/welder) and as you said above, the cost implications, but it shouldn't be expensive for some bits of welding and fiddling around... As for selling my jjr dump for $200, I bought it for $179 brand new lol......... And no defects mate, I'm not into screamers, plumb back's for me.
A little bit off topic but... Does anyone know if plumbed back external gates are legal in qld? Im guessing they are to a degree until the transport department pull you over?
I always thought external gates are legal anywhere as long as they are plumbed-back and dont dump poisonous exhaust gas into the environment
...as opposed to the good old sweet smelling exhaust gas coming out of the rear of the car.
I am pretty sure the fuzz will take a dim view of a big ol external gate sticking up if they see it.
No they aren't legal, mainly because any turbo other than stock isn't legal without an emissions test.
So I tOok the intake pipe off today cause I thoUght it was leaking air from the silicon hose cause I can hear a slight whistle/howl on boost, but I double checked all hose clamps on the turbo side and all hoses are on properly. I think it may be the turbo causing the very faint whistle/howl sound on boost an when backing off in gear the sooubd decreases with the revs.
I also noticed there was a bit of shaft play (left and right and back and forth) on the comp wheel as well.
Anyone else have some play on theirs?
BSA assured me he's had a bit too but i may just be a paranoid milkshake since I can hear it whistling/howling which leads me to believe it may be the turbos fault.
Any ideas guys?
