Kando Dynamics Turbo
SimonR32
The reason being I do not wana leave my car at any shop for more than a day ( I know it can be done in a day by a gun fabricator/mech/welder) and as you said above, the cost implications, but it shouldn't be expensive for some bits of welding and fiddling around... As for selling my jjr dump for $200, I bought it for $179 brand new lol......... And no defects mate, I'm not into screamers, plumb back's for me.
I meant to say its NOT going to cost a bucket load, wasn't concentrating.
You're going to find out the hard way that modifying your car is a process that takes time. You swap out injectors, afm, turbo and get it tuned; you're going to be without your car for more than a day. You can't do without your car then you can't modify it, you need to sort something out anway.
As for defects etc. an aftermarket internally gated turbo is just as illegal as an externally gated one. Just do it properly.
having a stupid looking car and driving it like a stupid then being stupid when you are confronted by popo will probably get you defected just for being stupid,
before an external gate will get you defected for having an external gate...
Lol at ARTZ, that little blue three wheeler on your avatar will surely get you defected mate. For 'driving an extraordinary and potentially dangerous car on public roads'..
haha...they have to catch it first ;)
Kando's turbos are great. My girlfriends sister has been running a td05-20g on her sr for a year with no dramas and cops a flogging more then often and my mate has had a kando td06 on his rb20 for nearly 6 months now pushing 27 psi on track days and smashes the fkuc out of it and no signs of smoke,shaft play or anything else yet,very happy with a 800$ delivered to door turbo.
awesome, can u tell me what rpm range the TD05 starts spooling on the SR. I just bought a TD05H 18G for $600 shipped. If u pay outside ebay he will knock about $100 off it.
What sort of power are they both making?
27 psi that's a bit drastic did you mean 17 psi? Mine didn't make any more power after 22 pound I'm fairly sure Roy found that to.
1.9ish bar of boost?
Pretty sure these (TD05,06, T67 and their like) wouldn't be able to flow more than 1.7bar (which is what trust quote for similar frame misti's, I would assume that the Kando are much the same). They seem to run out of their efficiency at around 1.5ish IIRC.
Edited by Wheezy
I just read through this whole thread, very interesting read and long lol.
has anybody actually had a td06sl2 20g(external gate) tuned running yet?
also I know a 8cm rear housing is a little small for a rb25 but has anybody out there tried one? Im considering it as I already have a trust td06 kit which needs a rebuild and its a 14cm rear lol, so I want to get a 10cm but Kando/kinugawa dosent have them in 3 bolt flanges. So am considering getting a TD06sl2 20g and running it with a 8cm untill I can find a 10cm turbine housing to swap onto it........ thoughts???? Note im also waiting on a reply to a email if they can get me a 10cm 3 bolt but its the second email and so far no luck
Unless somebody out there has a 10cm and wants a 8cm or a 14cm I could buy the same turbo and swap housings I guess
That won't fix my problem, I have a trust exhaust manifold so I need the mitsu housing ( same as Roy ) unless I change the flange on the manifold, which I don't want to do
Edited by JLTS13
Sounds fine. You will be able to get a 12cm item which should work nice. A little laggier but hey... Cant have everything lol.
If search TD06 triangle housing, you will find the Kando listings for the item. Sometimes they have Kinugawa in the description also.
If you need help determining which housing to get its simple, measure the outer diameter of your turbine wheel. 61mm SL2, 65mm Standard TD06, 67mm TD06H.
    • Anything for a 2003-2005 G35 will fit an M35. Just be mindful about clearance if you're running a plenum spacer or runner spacer.
    • You know how I know I'm getting old? Because I feel this quote jells with me and SAU Forums, ha ha ha. I've gotten lost a few times as I had muscle memory to scroll to where I wanted on my phone and just click, now I'm lost... Ha ha ha     "I used to be with ‘it’, but then they changed what ‘it’ was. Now what I’m with isn’t ‘it’ anymore and what’s ‘it’ seems weird and scary."
    • You don't lose spark if your battery isolator isn't wired correctly and the ECU still has power from the alternator.   Car has an epic wiring problem. Sounds like power connected really really badly in places. Possibly a power pin on a ground pin for the ECU, and constant power in locations that should be switched ignition.   It needs someone good at diagnosing electrical, a good multimeter, and someone with the wiring diagrams to match the engine loom that has been put into the car, and wiring diagrams for the body side of things from the car.
    • Hi folks, what options exist for PNM35 or what models share the same dimensions and fitment for the front top of tower strut brace. I have seen a few options pop up through Google, the Ultra Racing Australia for one. I have seen some eBay ones that claim they fit C34 and M35 but can't find details if to work out if its true. Also found Taiko / TEMA4x4 claim the one type fits: - Nissan Stagea (2-nd gen; M35) 2001 - 2007, - Nissan Skyline (V35, HV35, NV35, V35, PV35) 2001 - 2007 - Infiniti G35, G35X (3-rd gen; V35) 2002 - 2006 But not sure how true that is. Anyone fitted one or know of someone using one and can confirm what does fit?
    • I got the full kit.   The compressor as above is much smaller and lighter.  Also quieter. Bracket is visually mint and much lighter. The dryer and heat exchanger(rad) are one unit. Also smaller and lighter.  Much more room for an oil cooler. The fan I got was a bit Meh and I might change it.   And above all else it is more efficient, tested a good 3-4 degree's cooler than the old system, which is a lot. Disclaimer though - It wasn't a back to back test given different days. It really does feel colder though(always).  And this example is in my car with that crusty looking old compressor, not new vs new
