I've been waiting around 6months, a little longer won't hurt I guess.
So have you heard that they will release 10cm housings Roy? Or did you mean I may get lucky and come across a turbine housing?
Edited by JLTS13
Have you thought about trying an 8cm? Maybe it wont be as bad as you think.
The 3 bolt flange is said to flow 30% more than a square flange, maybe with a big gate it will work fine and be even more responsive? You could always try.
Gtscott I think that's what I will try, can't see the harm in giving it a go. And I can always change the housing at a later date.
Im interested anyway to see how it fairs against the 10cm on a rb25
And I'm running a 50mm gate so maybe it may help control it a bit
Edited by JLTS13
Got a dyno sheet? There has been some interesting discussion on how much the TD05-18G can make. Is yours an external setup or internal? Love to know what it will make on pump :)
Yeah got one but just got to load it up
Internal gate
And I had the same turbo previously on pump 98 made 231rwkw on 19psi but I only had 555cc injectors then so was limited by them not the turbo capable of more with more boost like now
Still ran a 12.5 @118mph at wsid with 231rwkw I'm hoping I can run a high 11 now with the extra 22kw
Edited by hy_rpm
Internal gate
Your not the dude I met at St Marys station for the .64 housing are you?
Roy I read it on the FP site amongst other places.
Actually its sold lol, collected money for it yesterday.
Im confident theres nothing wrong with the disco itself but its a bad match to the high comp motor and the cams are also shit.
I did say you would make the 250-260 mark mate. A nice result, but like weve been discussing theres possibly more in it with another exhaust housing, probably not worth the hassle tho.
How responsive is it on the street?
so having issues getting mine tuned atm. its only making 230 at 1bar
it hits full boost by 3700 (20psi, my tuner says this is very fast for this size turbo)holds it flat to about 5000rpm and dies back down very quickly to 1bar (gate pressure).
initially thought it was the BOV leaking so my tuner blocked it off and it helps a bit but it still dropping off fast after 5000 rpm.
my tuner has double checked everything and can't see anything wrong with the setup or any loose clamps or hoses.
his conclusion a) the rear housing is too small for it to drop off so fast up top (even if it was the smaller housing, the 8cm it should still hit 250~ and hold boost flat like BSA's results) or b) the manifold is restricting (but its been proven that the stock mani is good for 300 so that rules out the mani).
i did question a few pages back why the kando rear housings were so small compared to Trust/Greddy items but then its the same rear hats on simons T67-25G and he hasn't had any boost issues.
td06sl2-20g
stock manifold
tial wg44mm (1bar spring) plumbed back to exhaust
greddy profec B Spec2
no cat
hybrid style cooler with 2.5" piping
3" alloy intake with 3A racing filter
any ideas guys? pretty disappointed right now.
Have you considered the gate mod to the manifold might be holding it back? I wonder what would happen if it was plumbed off the rear housing instead with an intact manifold.
And that is some pretty rapid spool. Will be interesting to see the final result. Don't forget Jez has the same turbo and housing.
