Kando Dynamics Turbo
SimonR32
yes and jez had boost issues as well but that was because of his gate.
BSA had the same gate mod and he didnt have any spool issues and his was plumbed up the same way as well.
im gonna try with a bleed valve or borrow a profec b2 off Jez if he has time, so we can try it out.
It isn't the manifold so far it will hold gate pressure till red line but with abc on it spikes then drops to gate pressure. There is no way that the manifold is stopping power so far.
it doesn't spike Blake, it just won't hold
no matter what boost (higher then 1 bar) he puts in it will hold till 5000rpm and drop down to gate pressure.
pretty devo atm, my old setup was faster than this Lol
i am thinking of just getting a bigger spring, would this sort it out?
21psi springs. rip out EBC & sell it.
anyone here have bigger wastegate springs i can borrow to trial?
I had a 17 psi set up but changed to 10 with a boost controller I would just try a few different springs and aim close to target boost
mm. well its nothing to do with them that its dropping boost.. I just wanted to know.
I dont think the issue is in the turbo either, that rear wheel and housing combo has been proven plenty with the T67s and I doubt the 20g will throw it off that much that it caps out that early.
Try get the boost to stay on I guess. Did you try running a higher duty and lower gain? IE slow spool with high target?
My issue was opposite. I had boost creep due to a small 34mm gate.
Try plumbing the boost line into the top of the gate to help hold it shut. 5minute job, other wise come grab some springs and the profec b solenoid and control unit to try
Yeah, my tuner played with the gain, it doesn't make a difference.
thanks mate, getting it back tomorrow morning so will give it a try then. the MVR springs won't work with my gate :(
Have you considered the gate mod to the manifold might be holding it back? I wonder what would happen if it was plumbed off the rear housing instead with an intact manifold.
And that is some pretty rapid spool. Will be interesting to see the final result. Don't forget Jez has the same turbo and housing.
Yeah I would be looking at the manifold/gate arrangement
dont think this would be the case Simon, Blake (BSA) had the same manifold setup (but smaller gate) on his car and it wasn't an issue
what spring are you using in your gate at 1.5 bar ?
Has the boost controller been set up properly?? I am only using two 7psi springs in my Comp-gate40, but with the boost controller it holds 20psi dead flat.
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
    • If you really want squish back, you can have it put on the piston (at least to some extent).
    • Impressive. He's very very smooth.
