well its either an 8cm or a 12cm for you, id say 12cm will still be less than optimal for drift but 8cm might just work.
I seem to say this a lot but if you read the entire thread you will find some comment on 8cm variants on RB25s throughout. Earlier in the thread status actually commented on how an 8cm T67 acts on an RB25...
I can only assume the SL2 wheel in an 8cm housing will work easier being driven by a 20g than it would a 25 :) now time to read the entire thread.
yeah we used to use alot of 8cm instead of 10cm but the small gain in response is countered by the massive loss in mid and high end torque. will post a comparo on friday when im back at the shop. Its uprising how much the 8cm holds the turbo back on a 2.5 litre.
This is good timing, a decision I've been pondering fits well into this actually. I'm helping with a budget build of a turbo Honda running an F20B engine (basically destroked H22A, makes 147kw stock) which will be running ~11psi - I have been seriously considering recommending one of these turbos with an 8cm hotside for it.
I know on an RB25 would better suit a larger housing given you'd be pumping more boost into etc, but what about a slightly smaller engine which flows similar to the RB25 but will be running lower boost - do you think in these circumstances the 8cm may be more suiteable?
As normal, aims are for a reliable turbo which isn't too laggy and particularly in the case of a +T type build, keep intake temps and exhaust pressure nice and engine friendly.
there is a car you should look at on NS called JET200. Its nothing special but it documents the guys experience with a T67 on an SR. I think he ended up wanting shorter gearing and a much higher rev limit despite notable gains when going down to an 8cm housing.
What's the power goals of the Honda? In any event I think the T67 isn't a great option at 11psi anyway.
Ahh I mixed Jez and Status' post and thought the latest talk was about TD06 20G setups.
I was thinking a 20G with 8cm housing, car is currently running some kind of Ebay GT3582R look alike turbo which is both very laggy and potentially a grenade. Really anything thats nicer to drive and going to be reliable would be good, obviously T3 flanged a must.
I'm going to be tuning it on a Dynapack, so should be looking at easily >220kw on 11psi.
I will be tuning an internal td06 20g next week, but this one is different, the customer has removed alot of material to make the flow alot better out of the normally poor flowing gate.
Interesting to see the results. Good work on giving it a go. I would think you could get away with milling out all the centre/bridge and drilling and tapping an additional bolt hole for mounting a big bellmouth dump pipe. Or are you going to try and split the the gate and turbine gases?
Something makes me think that central bridge is the restriction itself..All those exhaust gases flowing out of the exhaust housing and wastegate hole would be at some point partly hitting that bridge, deflecting off it and being a restriction to the overall gas flow, hence more force required by the engine to push them out = less power / crappy internal gate housing design.. Just thoughts.pinch.gif
I cant believe this is even a debate. Its a 300 pesos manifold ffs. Nobody in their right mind is going to say its as good as the high end stuff.
What it is though is great value for money for the builder on a budget,I used it simply because it was convenient at the time. Pluses outweigh the negatives as far as I'm concerned.
A. price
B. performance
C. durability
As the dyno showed all these twats saying angle this and angle that are just that...twats. the manifold flows without restriction, If exhaust gas flowed in the opposite dierection the merge collector would be far more relevant, as it is 6 pipes feed in to the exhaust housing regardless of the shape of the merge.
I've run up 5 k on it so far. Its rock solid, no warping cracking leaking or shifting whatsoever.
Would I use one on my big engine...No. Plain and simple. Not because I m afraid it wouldnt work, merely because I cant get my head around a cheap job for a high end engine.
Bang for buck this is one of the best mods I have done to date.
Would be interesting if someone could mill out the bridge on those internal gates and weld a 6 bolt flange on there like stao does with the hypergears.
GTS scott, i can't get NS on my computer , what was the deal with JET 200?, did it pick up power with a 8 cm vs 10cm housing on the Sr20?
cheers
darren
Thinking about it further, does any of the Kando/Mitsi peoples think a TD06SL2-18G with 8cm housing could even work well for this setup - this is on a 2litre VTEC Honda running ~11psi for anyone who missed the first post I made about this.
I suggested that but he welded the blocking plate back on so still running the 3 bolt flange. He thinks he will gain a fair bit.
Will see when i tune it
From what I know the SL2 18g gives a more linear delivery than its 20g counterpart. But the only videos I have seen have been on mildly tuned 1JZ's. The outcome was as fast as the 20g from memory, but more of a passive aggressive approach rather than the brutal hit of the 20g.
Either way, your now talking about a result that doesnt warrant a big dirty TD06SL2 wheel. Here:
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-3-Anti-Surge-TD05H-18G-w-T3-8cm-V-Band-External-Gate-Hsg-/290677530717?pt=AU_Car_Parts_Accessories&hash=item43adbb205d
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
