i've searched and everyone says they're a waste of $$ on a RB25, with zero gains
Really? OK, I stand corrected. Everything I have ever read suggested that the RB26 and RB25 were the most responsive to cam gears, (a friend played with custom inlet cam gear on a NEO and got nothing from it...but an adjustable cam gear worked well on his exhaust side)...and RB20s respond well, but not as well as its bigger cc cousins.
I have read that cam gears were a waste of time and money if you were running Poncams. But...can't say I have paid too much attention to it the last 5 years...it used to be a golden rule
I quickly discovered a page or so back he hates one of the best engine makers in the world - based on that lot I'd not really expect him to have the kind of appreciation or understanding of optimising engine efficiency needed to treat as an authority on the topic.
i think it was Trent who mentioned something about cams being not worth their $$ on a RB25.
got a dyno sheet of this? if there is proof of gains i will get an exh cam gear.
Lithium, you referring to me about my honda post last page?
Cam gears , not cams! I have not heard of too many RB25s not responding well to cam gears on std cams.
As for dyno sheets? Hell man, we are talking around 2004-2005 when he made a custom inlet cam gear that could be adjusted as part of all his trial and error. It was all for 0 anyway as the setup worked best set at 0 and the exhaust side retarded a little using his off the shelf HKS exhaust cam gear
It all depends on the set up some rb engine greatly benefit from cam gears some not so much personally I think it would be a decent investment cos lets face it if your chasing power you have wasted money on worse things I know I have
Gone through the last 40 or so pages. Am I imagining things or are not many people running the TD06H-25G? I know heaps are running the 20G.
I am looking at this turbo http://www.ebay.com.au/itm/Kinugawa-Turbocharger-4-Inlet-TD06H-25G-T3-V-Band-10cm-AR73-500P-/270913941567?pt=AU_Car_Parts_Accessories&hash=item3f13bab03f
Im not a guru on turbos so I thought I would ask here. I want great response since ill be doing track days, am I looking at the right turbo? Chasing around 300ish kw.
I also noticed the two types, water cooled and oil cooled, which is better?
If you were looking for a easy 350KW on 98 would it be better to go as TD06SH 25G 12cm or T67 25G 12cm?
Whats the power difference between the TD06SH and T67?
I know the TD06SH has the 58.8 and 67 turbine wheels but would it push it enough to make it worth the lag?
sorry, it was a typo, i meant cam gears. i'm still against them until i see proof provide decent gains.
it will not be a decent investment after the $$ you spend for your tuner to tinker with them and to set them up especially after all the work and only to find maybe 1-2kw gain (if your lucky)? Lol
+1 i didnt notice any gain from my cam gear install
:yes:
You answer your own question the h has a bigger turbine wheel I had the td06h-20g on my 20 and was seeing full boost at 4200 18psi so it's only a few rpm if you want bigger numbers
:yes:
Haha depends if your tuner try's everything and not just turn up the boost. I don't think it wound be worth it on your set up because the turbo is already working very well. From what iv heard you can get more mid range and bring the turbo on faster that why I thought it would be worth it not so much power out put.
i've still yet to see a dyno sheet where it provides a gain in response in the mid range.
i've seen some results with cams installed but not with just exh cam gear adjustment only.
feel free to prove me wrong, i am skeptical until i see evidence that it works.
    • Interesting, I've heard complete opposite on my end. Bit of a lottery I guess.
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
