Yeah it doesnt look like its on. The curve is what id expect from WG pressure alone, which shows it is a really epic result :D
Sucks you have to do it twice but hey.. Im onto my 3rd attempt lol
You need to love cars to really hate them :yes:
very good results on only 15psi ARTZ sorry to hear about your clutch.
beats my poor results lol
and leave the screamer, stop being a girl :nyaanyaa:
Well the internal gate 20g sucked balls last night. Well it did perform well except it was running 21psi minimum. This on 98 octane, We got it up to around 280kw.
We tried everything to back the boost down, even had the wastegate flap off and was lazy onto boost but then ran 21psi after 5000.
Ill post sheet up later
not bad, my mate is going to run one on his SR.
was this a 8 or 10cm ?
lol dori was stuck on a bar because of control issues, its been sorted now and were waiting to see the final results.
your stuck on a bar coz your clutch.... was like a bar of soap!
happy trolololo !
its going in today,
results soon.
hopefully my clutch holds up too!
its being tuned with gate plumped up,
then BSA is gonna put a removable flange so i run it atmo.
then put it back on the dyno to see the power differences.
You will make 289rwkw peak power on 22psi/ 98 fuel. Prediction. And awesome bottom and mid range..:rolleyes: Hurry up with the tune already.
^ thats awesome mate thanks for sharing, helps me decide if i want one on my SR :)
Can you divulge the specs of that motor? Is it heavily moded or internally stock etc? headwork and cams? Thanks,
Also great to hear your getting back on the dyno today dori! cant wait
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
