whats the mods/specs/power output on your car Birds?
maybe you should do a run in 4th from 2000rpm, flatfoot and film the tacho + boostgauge at the same time (if its mounted there), and me or ARTZ can do the same.
will be good to compare.
Whys ur car off the road for 2 yrs?
Been off the road for 2 years due too the $$$, got carried away buying parts instead of keeping on track with the original plan........... Just saving for ECU and maybe cams then good to go :thumbsup:
I'll take a stab in the dark that, in a rolling scenario from low rpm (2000) my car should pull ahead, given it's the more "streetable" turbo and gets on boost from about 3000 onwards...until around 4000, where Artz would come on and start to reel me in / eventually overtake. From there who knows...probably come down to max power and turbo efficiency in the top end. The Kando might well take it there if Artz can get his slipping clutch sorted.
Would be interesting to test a couple of different scenarios...the rolling from 2000rpm to test lag, and a rolling from 4000rpm where both turbos should be well on song, to test their response (?).
We can swap cars just to get a feel for each turbo, compare based on subjective opinion...but the only fair objective competition would be a rolling drag IMO, taking driver skill out of it.
ahh yes, efficiency...I must say this td06 feels alot more efficient than my old hiflow, though I feel my new fuel system has alot to do with this as well. But it all just works, it does the same thing all the time and doesnt run out of puff, it does it with much less effort than my old turbo too, then on gate it all just gets a little crazy, should be mental with .5 bar more boost and e85, I think thats when I will be wishing I had top mounted it ......I did play around with rolling starts, found boost coming in after 3500 but before 4000 most of the time..which is about normal for any rb25 really..
Anyway I have no idea what yours will behave like all I know is mine feels pretty damn quik already, I think maybe when my gate cracks it will be bye bye birdy ,then again you will probably have better traction with that fancy diff of yours..will be interesting..
So whenever your ready just hit me up, if I do lose I can blame my slipping clutch or my low boost ;)
sorry, 300rwkw and under only Simon.
good news: it holds boost and i get my car back
bad news: it makes less power on 19psi (220rwkw) then it does on 14.7 (245rwkw).
nothing was changed on inlet side (same as old setup and there was no issues), hot side has been changed and not running a cat to minimise restriction.
any ideas?
Sorry no black cocks allowed
People with under 300rwkw like Black Cocks :whistling:
any ideas?
Got both graphs? Post them up
he's not sure if he saved the 19psi one, but ill def have the 14.7psi graph tonight.
torque goes up as normal and then drops off.
would vac/boost leak cause this?
if there was a leak, boost would not hold, or would it?
i will get more info tonight as he only briefly discussed the issues over the phone.
any ideas?
WTF? :rant:
If you remember Mick_O's midget with a trumpet saga, I was actually there the day it was diagnosed (I actually found the midget lol)
His car was still pissing in 300kw with the IM gasket blown between the plenum and the runners, in fact when it blew right out I dont think it was really that down on power. Boost curve didnt look right (coz it was trying hard to compensate) but other than that power was still there.
Im inclined to think you have some sort of a turbulence issue. It would be really good to see ARTZ crank 19psi right now...
yeah i read about that in his thread,
so pretty stumped right now as to what it could be.
will find out more info tonight.
im booking it into Jez in May to get it looked at. i've had enough dramas with this tuner, its time to move on.
May is two whole months away, r u serious? lol
going on holidays next month so nothing can be done until then
I ordered my smoke machine intake tester this morning. Bloody expensive thing but i think it will be a good investment. I charge 100000000 per test. U guys reckon thats fair ? :D
that's cheap as!
What clutch do u Have? Its possible it was slipping or wheelspinning.
if it was slipping or wheel spinning, he would be able to tell.
cant remember exactly but it was a Exedy heavy Duty something something.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
    • I say it often, none of this stuff is really Skyline-specific per se. But in general there's not a lot of people who actually know what they're doing. A lot of people charging like they do. Agile software development probably isn't the greatest idea for an engine controller.
