Kando Dynamics Turbo
SimonR32
We had an Epic fail last week on the dyno with an Evo consistently running 169-176AWKW..... Changed plugs, checked for leaks...Checked everything...
Turned out is was simply bad E85... Replaced the tank of fuel and BAM 300+AWKW first run.... We laughed at the end of the day but were a bit annoyed that it was something easy...
Fingers crossed its just clutch slip or something easy man :thumbsup:
E85 Strikes again lol
So others are having similar issues? Or is it just a storage issue? I plan to go down that path very soon so just want to eliminate potential sh*tfights if possible....
sorry, 300rwkw and under only Simon.
good news: it holds boost and i get my car back
bad news: it makes less power on 19psi (220rwkw) then it does on 14.7 (245rwkw).
nothing was changed on inlet side (same as old setup and there was no issues), hot side has been changed and not running a cat to minimise restriction.
any ideas?
Ouch, it didn't meet expectations I guess. Sorry to hear, if i remember correctly, did ARTZ make around 245rwkw on 14.5psi?? Same setup too isn't it.
fresh fuel before it was dropped off from my trusty local Shell Servo, never had an issue with petrol tbh lol
who knows what it could be, im gonna play around with it when i get back and will check for any damaged silicon hoses etc, i will send the map to Jez and see if he can spot anything unusual.
he made 267 rwkw
he made 267 rwkw
How does it drive though? Strong n aggressive? Or not too snappy..
picking it up tonight.
but judging from last time it had boost issues, 1 bar felt pretty slow (compared to my old setup with similar power)
Its common for people to have E85 based issues, the fuel takes on water very quickly and is prone to it when stored. That goes for in the tanks at the servo too, remember that not many people run flex fuel cars so the fuel wouldnt sell super quick nor get restocked super quick either.
Remember also that Caltex eflex is a varying content fuel, meaning without a content sensor type ecu and appropriate tune you would want to be buying the CSR shit in barrels **No offense to people on the eflex bandwagon!!**.
My personal theory is to stay 98 till eflex goes mainstream, then i will get a content sensor ECU and go balls out.
Just as an FYI, ARTZ failed results are currently on par with hypergears FNT G3. The boost does come on 500rpm sooner, but it doesnt appear to be making any extra power at this stage (midrange). Hopefully a stout boost up once his clutch is fixed will change that, otherwise HG may have it in the bag (remember ARTZ and Stao use the same dyno/tuner).
I don't wanna jinx my own tune with my HG, but maybe this is some sort of karma for your stirs in the HG thread, when people had problems making the power that they expected ;)
I already know G3 can make more power than I will
At the moment (with your low boost and slipping clutch) its also matching you for response (sad panda).
Yet you will probably also nearly match it for power (IMHO), yet who knows... Maybe the new clutch and much more aggressive boost curve once fully tuned will yield more midrange :thumbsup: I'm pretty sure you will get close to 290kw with the thing, your most way there and still 5psi off target.
here is the dyno sheet;
the line with red dots is the 1.4bar run, it gets good torque but then drops down and doesn't go any further than 180kph (6000rpm) at this time, its missing and running rich and there was black smoke everywhere.
appreciate any feedback on this.
cheers
On the high boost run the lines are all over the place presumably due to a misfire, whether its dodgy tune, dodgy coil, valve float or something different - who knows.
The build up of midrange looks good, I definitely wouldn't blame the turbo for the poor 1.4bar result... some issue needs to be resolved. Could end up pretty good once sorted :)
Other than that, more subtle bumpiness in dyno plots are often more to do with "smoothing" the dyno software does on the data it gets from hardware than how than the car is actually running. The data generated from the dyno is less than perfect, if it were plotted in its raw form it'd look more like a bunch of random dots with a general trend which might look a bit like it could be a curve.
The software has the unenviable job of finding a delicate balance of making it into a curve while keeping as much of the finer detail as possible but also keeping it "readable". Smooth it too much, and you could lose useful information - smooth it too little and it could end up just looking like a random lightning bolt. Also, the more you smooth it the lower the reading will be as it effectively draws the "highs" and "lows" closer together. While not a dyno example, this is the kind of thing that will be going on:
Whats the ECU/Engine setup?
Out of interest, can somebody explain why some curves are all wavey and all over the place like that? Is it the resolution/scaling?
When they are big waves it is somewhere in the tune (be it TUNE itself or mechanical tune state of the motor ie faults)
When they are small sharp waves it is normally the dyno sheet resolution. Once you compress the sheet it looks smoother.
In Dori's case its anyones guess right now. Could be spark breakdown, bad CAS signal, bad fuel pressure, poor WG control or clutch slip. Right down the bottom of the list I would say potentially a shit tune, but that is like..... Last option.
Make sure you have constant fuel pressure, double check both your dampeners are still in place, make sure your CAS wiring is still good and double check your clutch isnt letting go. If all of those come back perfect I rekon you have a turbulence issue in the hot side. If only you could borrow ARTZ manifold and housing to test.
cheers for the response guys.
its a Rb25DET NEO
td06sl2-20g 10cm
44mm tial gate fitted to stock exhaust manifold
haltech PS1000 ecu running map sensor
walbro fuel pump (rewired for constant voltage)
600cc highflow injectors
3" dump/front, no cat, 3.5" HKS hipower
2.5" hybrid style FMIC
CPC custom plenum
3A racing pod filter with 3" metal intake
GTScott is right, could be so many factors right now :/
When you say -
It makes it sound like a spark issue as if its blowing a lot of black smoke it sounds like it should have plenty of fuel? Do you run Splitfire coils or similar man?
These are my 2 concerns.
When you installed the pump did you ensure you left the fuel dampener in place? AFAIK the rear dampener is in the tank, in line with the pump (but i could be wrong). Double check this asap.
Im also dubious of the gate off the manifold. Because it branches off at the splitter I'm worried that the flowpath is disrupted by turbulence/reverberation from the WG tube going from one side of the splitter and back to the other. I know people will bawk at me and say no way, but i say yes way definitely possible. Remember the manifold has a true split up to that point, with exhaust pulses mixing at the pinch point when you blow a hole in the splitter. In this case mixing in the WG tube which doesnt extend at all beyond the split.
Could even be the turbo! Or Artz' car has some sort of secret squirrel stuff done to it :rolleyes:
Neg. The turbo is a simple item, simple known working combo (unless it has shat itself which I doubt).
When you say -
it isn't starving of fuel or anything like that
running JJR coilpacks
it isn't an ignition related missfire.
the walbro pump ran on my old setup and that ran 18psi without any issues.
BSA ran the same manifold setup on his and it held 17 or 19psi.
my tuner tested it on 1bar, 1.2 and 1.4. both the 1.2 & 1.4bar runs had the same issue and both made less power than the 1bar run. so it seems like anything more than 1bar, its not liking it.
maybe i should've rip this out and go with a HG turbo? oh wait, ill have the same issue.
    • So, as it turns out, a new wire was the answer I went for, but getting there was not straightforward... Firstly, I'd been told before by shops that had worked on the car that it had some weird factory wiring, and I can now confirm that is true in at least a couple of places. For example....that very purple/white wire that provides IGN power to ECU pin 31.....I traced it out of the ECU loom into a connector high on the nav's A pillar under the dash, where it headed up and out of site across the dash, then back down at driver's A pillar. After trying about 8 different relays I found it coming into the back of the fuse box, and confirmed it was the same wire with a multimeter* (more to follow on that.... So, which fuse is the ECU IGN power connected to in my car?  Very top right, labelled IGN (good), 10A (good), Auto Trans Control (WTF?). It's not impossible it has been f**ked with before, but if so someone removed the pins from the back of the fuse box and moved it somewhere else, noting an AT control fuse would be functionally useless as the car was auto converted to manual long ago. It is not simply a wire cut and joined to the wrong place, both ends of the wire are the same colour just one is in the wrong location (you can see there is an IGN Engine Control fuse in the bottom row 4th from the right. Note, that is the fuse box sticker from my actual car, so either I have the wrong coin holder sticker, someone f**ked with it post factory, or factory sticker does not match the wiring.....whichever option it is just plain weird. Undermining the likelihood of someone having gone to that trouble to move a power feed when everything else in the loom had already been butchered....the fuse next to it IGN 7.5a ABS doesn't even have a wire running to it....so no idea where that fuse is on this car. All strange. But not the problem with my ECU power.
    • New tank clean paint and install complete 🤙
    • I have heard the frenchys kit (with the smaller toyota compressor) performs fantastic. i havent actually gassed my system yet, so cant confirm myself..
    • https://www.efisolutions.com.au/injector-lower-manifold-collars-adapters-r33-a32-y?gad_source=1&gclid=EAIaIQobChMIjpXb2aLaiAMVYcA8Ah1zkg6JEAQYASABEgJzG_D_BwE
    • correct Ive moved to a r33 oem ball joint - they are actually thicker than alot of the after market and similar
