I get my content woes/information down a short grape vine from the very top of CAMS hierarchy. Not that it changes anything, but like I've said before we all form our opinions somehow.
Not a good source for information imo. Too many kickbacks from the race fuel industry perhaps?
Trent has tuned countless times with Eflex and C16 with little difference in performance or safety. I know which one I would rather pay for in my daily...
My kando/kamak T67-25G 10cm finally turned up today after a few delays, Compressor housing hits rocker cover so RB20's will go on, weld V-band and wastegate off exhaust housing tomorrow.
RB25/30, fresh rebuild
stock rb30e piston & rod
stock RB20in RB25ex cams, No VCT
ebay stainless manifold
Freddy plenum
80mm throttle
Tial 44mm MVR
Apexi Power FC
Splitfires coilpacks
Nismo 750cc
Modified twin feed rail
Twin bosch 044 pumps
Surge Tank
E85/Eflex fuel
Previously GT3076R :yes:
Your probably not wrong, I wont go there for now. Hate 'he said she said's', especially on the net lol. V8s did end up going E85 though, but with the guaranteed content CSR shit.
I have heard reports that eflex is fairly consistent at the e70 mark.. But I just cant get past the fact its a varying content fuel. Like I said in the HG thread, I fully believe in it as long as its used with a content sensor.
Once it properly rolls out in NSW and is available everywhere I will honestly be buying a flex capable ecu and getting it tuned on that :)
Freddy plenum
80mm throttle
Tial 44mm MVR
Apexi Power FC
Nismo 750cc
Surge Tank
E85/Eflex fuel
INSANE
Hi guys
After a little help and thoughts on the set up Im thinking of changing to. Its an SR20DET in my 180sx currently running a 2871r 56trim .64exh with HKS step 2 264/264 cams and supporting mods, it makes 268 rwkw on 18psi tuned on E10 100oct.
Im looking at going to the Kinugawa TDO6SL2-20G T3 V band 8cm high mount with Tial 38mm external gate.
So a few Q's
Will this get me close to 300 rwkw on 18-20psi?
Should I look at the 10cm housing or stick with the 8cm?
Will the 38mm gate be big enough on an SR?
Im keen to keep full boost of 18-20psi around 4000rpm.
Thanks for any input.
Cheers
Edited by slippylotion
Found a cheap Evo turbo td05-16g I can get 2 for a catch can would these be any good on a 26
I have a twin td05 kit off a rb26 , in memory it made close to 400 rwk and ran a 10sec quarter , I'm about to put one on a rb20 , hoping to see 200rwk
Is there a difference in sizes between a T2 8cm housing and a T3 8cm housing?
I know obviously the T3 flange is bigger but does this also mean the total volume is also bigger. So is a T3 8cm sort of the equevilent of a T2 10cm?
