Talking about the internal gate versions, have u guys seen these ones ? They would have to be better than the v band outlets. Any results ?
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-2-4-Nissan-RB25DET-R33-TD06H-20G-12cm-450HP-/270967681626?pt=AU_Car_Parts_Accessories&hash=item3f16eeb25a#ht_2166wt_1396
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-2-4-Nissan-RB25DET-TD06H-w-Garrett-60-1-12cm-500HP-/270967681598?pt=AU_Car_Parts_Accessories&hash=item3f16eeb23e#ht_2183wt_1396
Im having trouble finding a dump flange/pipe that would suit. Sorry if these have been covered already, this thread is huge
I've just heard that if your running high boost with these turbos you need to upgrade the h/duty thrust bearing to a better quality one. apparently the evo guys are doing this if running over 18psi. It already comes with a hd thrust washer but they say the quality isn't that great for higher boost levels.
Any thoughts or experience on this guys? Since I haven't fitted it yet I can upgrade it if need be.
Because the boost falls over at the top it seems inconsistant with boost creep as creep should keep climbing all the way to redline. But 38mm is right on the limit.
What im saying is use te boost controller to try and run 18psi solid from 4 to redline. If he had not control at all with the boost then the boost controller lines are back to front
So, has anyone else noticed the emergence of KAMAK on ebay, other than our beloved Kando Dynamic range?
There's an AUS distributor selling them for about 3x the price of what Eiji does. He advertises they are balanced to 100,000 rpm but Eiji states 150,000 - both on a VSR machine.
One thing that is weird is the KAMAK branded items are running some sort of weird 9 blade turbine wheel and are boasting improved response and top end flow. I'm not sure if I'm sold here..... Anyone want to share an opinion?
Check it out here:
http://www.ebay.com.au/itm/Nissan-Turbo-HIGH-END-TD06SL2-20GTX-AR-8-Nissan-Silvia-S13-S14-200SX-240SX-/140744047319?pt=AU_Car_Parts_Accessories&hash=item20c4ffbad7
Also, here is a genuine trust turbo with one of those horrible housings.
What were they thinking....
http://www.ebay.com.au/itm/Trust-Greddy-Turbo-TD06-20G-/230785422581?pt=AU_Car_Parts_Accessories&hash=item35bbe214f5
Check it out here:
http://www.ebay.com....=item20c4ffbad7
Turbine looks similar to what stao used in my SS1PU
Hey guys.
Bit of a noob with turbo specs etc (ar's housings etc mean nothing to me).
I am after a internally gated turbo that I can put on a stock manifold and I was recommended to look in to Kando turbos. I have no idea what all the different specs mean.
But long story short, I am after a responsive turbo and looking at around 230 to 250 kw.
Is
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-RB20DET-RB25DET-2-4-Cover-8cm-T3-V-Band-TD06H-20G-/290701940216?pt=AU_Car_Parts_Accessories&hash=item43af2f95f8#ht_2545wt_1184
The one I want?
What does "Cover outlet needs to be modified with silicon hose." mean.
Sorry if noobish questions.
Thanks guys.
    • Cool to see you're on the forum man, think you've met my twin brother a few times (Brent).
    • Yeah everyone always seems to refer to them as S13 wheels however they came on R32 Skyline, A31 Cefiro, C33 Laurel etc., and also came polished diamond cut or painted depending on the model. Congrats on your GTS purchase! I'd personally leave it NA.
    • In this thing about this 100% renewal energy stuff I hear no one really talking about anything other than power and fuel really Power and fuel, whilst being a huge part of how we use the billion year old Dinosaur juices, are only 2, of the probably thousands of things that we need to use it for in the chemicals industries for making nearly everything we use nowadays I'm all for a clean planet, but if we want to continue to have all the day to day appliances and stuff that we rely on everyday we will still need fossil fuels Whilst I do love science, and how it can bring innovation, there's really a limit to how far it can go in relation to "going green" As for EV's, unless your charging of your own solar panels, it isn't helping the environment when you consider the the batteries, the mining processes required,  the manufacturing process required, and how long a batteries (read: the vehicle) lasts long term If I was supreme dictator of the world, I would ban the use of sugar for fizzy drinks and food additives and use that for ethanol manufacturing, petrol engines would be happier, and people would be alot healthier  Disclaimer: Whiskey manufacturing would still be required, so says the supreme dictator of the world Same same for all the vegetable oils that get pumped into all our food, use that for bio diesel Disclaimer: the supreme dictator would still require olive oil to dip his bread in This would take some of heat off the use of the use of fossil fuels which are required for everything we use, unless you want to go back to pre 1800 for heat and power, or the early 1900's for plastics and every thing else that has come from cracking ethylene  Would I be a fair and just dictator, nope, and I would probably be assassinated within my first few months, but would my cunning plan work, maybe, for a while, maybe not Meh, in the end in an over opinionated mildly educated arsehole typing out my vomit on my mobile phone, which wouldn't be possible without fossil fuels And if your into conspiracies, we only need the fossil fuels to last until a meteor hits, or thermonuclear annihilation, that would definitely fix our need for fossil fuels for manufacturing and power issues for quite some time  Meh, time for this boomer to cook his lunch on his electric stove and then maybe go for a drive in my petrol car, for fun
    • It really helps that light duty vehicles have absolutely appalling average efficiency due to poor average load. Like 25% average brake thermal efficiency when peak is somewhere around 38% these days. So even a 60% BTE stationary natural gas plant + transmission and charging losses still doing much better with an EV than conventional ICE. And that's before we get into renewables or "low carbon nonrenewable" nuclear which makes it a no-brainer, basically. In commercial aircraft or heavy duty diesel pulling some ridiculous amount of weight across a continent the numbers are much more difficult to make work. I honestly think in 5-10 years we will still be seeing something like the Achates opposed piston diesels in most semi trucks running on a blend of renewable/biodiesel. Applications where the energy density of diesel is just too critical to compromise. CARB is running trials of those engines right now to evaluate in real world drayage ops, probably because they're noticing that the numbers just don't work for electrification unless our plan is to make glorified electric trains with high voltage wires running along every major highway and only a token amount of battery to make it 30 miles or something like that after detaching. Transport emissions is not insignificant especially in the US, but yes there's a lot of industrial processes that also need to be decarbonized. I agree the scale of the problem is pretty insane but EDF managed to generate ~360 TWh from their nuclear reactors last year and this is with decades of underinvestment after the initial big push in the 70s and 80s. I don't think the frame of reference should be solar-limited. France is not exactly a big country either. Maybe it doesn't work everywhere, but it doesn't have to either. We just can't live off of fracking forever and expect things to be ok.
