I did consider the 20g also, but might not make the 280-300kw I want with a turn flow. And if it did I would need a few more psi. Dori33 and I went to a drift day and he has a 20g and it got super hot. So running slightly less psi will hopefully drop the temps a little.
plus by the time u setup an external gate its going to cost you another 600..
HG turbos are known to be reliable..I know theres alot if drifters down here using them..
The varying results you see are usually to do with setup not the turbo
I'll be going external gate whatever Turbo I go. As it transfers excess heat away from the exhaust wheel and won't create turbulence. That cost has already been covered. Thanks for the input. I may consider a 20g.
Ahh ok..just don't mount the gate on the exhaust manifold..its crap :P
what makes you say its crap?
making claims without any proof, i can say that mounting the gate on the turbo housing is crap too.
just changed over to the anti-surge slot front housing, changes the induction noise completely, sounds pretty good.
feels slightly more responsive in 3rd. going to Jez in 2 wks for touch up tune, hopefully can completely rid of the light surge in 4th and hit 21psi.
Video or ban! :P Fingers crossed for MOAR good things when the higher boost goes through it!!
2 weeks you say eh? I just might have to meet up with you there!!
Hes taking the piss.
yeah i hope so too, otherwise just leave it as is and time to enjoy.
hows your car going?
Still waiting, another week or two i think.... And YES we will have to organise a cruise.... Kando vs Garrett cruise? :P
Vs HKS once Im on E85 as well...
Perfect :thumbsup: Just need to corrupt Dori onto it as well......... Hanaldo will have to come here for that as WA sucks apparently :sick:
