I did consider the 20g also, but might not make the 280-300kw I want with a turn flow. And if it did I would need a few more psi. Dori33 and I went to a drift day and he has a 20g and it got super hot. So running slightly less psi will hopefully drop the temps a little.
plus by the time u setup an external gate its going to cost you another 600..
HG turbos are known to be reliable..I know theres alot if drifters down here using them..
The varying results you see are usually to do with setup not the turbo
I'll be going external gate whatever Turbo I go. As it transfers excess heat away from the exhaust wheel and won't create turbulence. That cost has already been covered. Thanks for the input. I may consider a 20g.
Ahh ok..just don't mount the gate on the exhaust manifold..its crap :P
what makes you say its crap?
making claims without any proof, i can say that mounting the gate on the turbo housing is crap too.
just changed over to the anti-surge slot front housing, changes the induction noise completely, sounds pretty good.
feels slightly more responsive in 3rd. going to Jez in 2 wks for touch up tune, hopefully can completely rid of the light surge in 4th and hit 21psi.
Video or ban! :P Fingers crossed for MOAR good things when the higher boost goes through it!!
2 weeks you say eh? I just might have to meet up with you there!!
Hes taking the piss.
yeah i hope so too, otherwise just leave it as is and time to enjoy.
hows your car going?
Still waiting, another week or two i think.... And YES we will have to organise a cruise.... Kando vs Garrett cruise? :P
Vs HKS once Im on E85 as well...
Perfect :thumbsup: Just need to corrupt Dori onto it as well......... Hanaldo will have to come here for that as WA sucks apparently :sick:
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
